Old 07/11/2014, 09:49 AM   #1
Default Honda Pilot Vibration. Help!!
Hi guys, my mom has a 03 Honda Pilot with a v6 3.0l. There's a vibration coming from under the vehicle. It only occurs while driving on flat surfaces at 30-40 mph. The vibration comes and goes when let off or by pressing the gas. It's a very loud vibration and can be felt throughout the vehicle.
Has anyone delt with this before or at least a link they can share with identical issues?
I'd like to get this figured out and fixed before it gets any worst than it is.
Thanks in advance!
Old 07/11/2014, 09:51 AM   #2
Default Re: Honda Pilot Vibration. Help!!
Also, it has new brakes all around, and new wheel bearing. Vehicle has roughly 183,xxx miles and running strong.
Old 07/11/2014, 01:16 PM   #3
LowNsloEJ6
1SickUA7
LowNsloEJ6's Avatar
LowNsloEJ6 is offline
AWD model?
08 TL-S
97 EJ6 D16Z6
Old 07/14/2014, 02:04 AM   #4
Originally Posted by LowNsloEJ6 View Post
AWD model?
Yes
Old 07/14/2014, 07:28 AM   #5
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
ConHuevos! is offline
put it up on a hoist get under the vehicle and have someone accelerate the vehicle to 30-40 and inspect drive axles/drive shaft for wobble.
also you could check tires while you are there. don't overlook the obvious. good luck
Sri Sri Ravi Shankar
Old 07/15/2014, 06:00 PM   #6
Thanks for the reply. I have not checked tires yet. Although, I was leaning towards the mid section axle or the load axle bearing.
But it's strange that the vibration only comes when cruising at approximately 30-40 mph. Once it's at that speed range, the loud noise/vibration goes away when braking or accelerating.
I'll definitely will verify both suggestions to see if I find any unusual movements
