Old 09/10/2014, 10:28 PM   #1
arsalan500
arsalan500's Avatar
arsalan500 is offline
Default 02 g20 sunroof
got this p11 g20 laying around with a sunroof leak.
I found the drain holes, and saw a bunch of water just sitting near it, so its obviously clogged, i need to know the outlet for the sunroof drain hose is, any idea?
checked the repair manual and its not very specific, all if told me is that it goes down the A pillar and somewhere aroung the fender is released.
1995 Eclipse GSX(Project Rebuilding)---------------Still Own
1995 Eclipse Gst(Good Dsm)-------------------------Still Own
1994 Honda civic, b16 swap, Blacked out-----------Still Own
1997 Nissan maxima (rebuilding)--------------------Still Own
Old 09/11/2014, 08:05 AM   #2
LowNsloEJ6
1SickUA7
LowNsloEJ6's Avatar
LowNsloEJ6 is offline
Default Re: 02 g20 sunroof
rear go through the trunk and exit behind the bumper on the side of the car. if you pull the trunk wall carpet back you can see it. the fronts go throught the a pillers and drain behind the fender.. blow compressed air throught the drain holes in the sunroof area.
08 TL-S
97 EJ6 D16Z6
Old 09/11/2014, 05:25 PM   #3
HANDA
HANDA's Avatar
HANDA is offline
Did you get this resolved?
