Old 01/16/2009, 07:40 AM   #1
eirek4
eirek4's Avatar
eirek4 is offline
Default RSX Idle Problem
so this morning heading to work the rsx decided it wanted to start idle surging.. any ideas as to what would cause it to start doing this all of a sudden.. Its freezing out so havn't had time to look at it really just yet!
Old 01/16/2009, 12:13 PM   #2
jdmwhore09
jdmwhore09's Avatar
jdmwhore09 is offline
Default Re: RSX Idle Problem
could be a leak on the intake manifold. either gasket or vacum hose. or the idle air control unit or what ever its called on the back of the intake manifold
09 civic si
dirtbike crew#10 11ktm 300
Old 01/16/2009, 12:47 PM   #3
Dc2Ninjah
Dc2Ninjah's Avatar
Dc2Ninjah is offline
have you done the hondata img or tb spacer?...it is pretty chilly out. hahaha its sooo cold my rsx barly started and tipped the srs light cause of very low voltage.fawkin ayyy....
Old 01/16/2009, 01:40 PM   #4
jdmwhore09
jdmwhore09's Avatar
whats img? and your thon right my buddy trav talks to you i think
09 civic si
Old 01/16/2009, 01:48 PM   #5
RICKYritethere
Work
RICKYritethere's Avatar
RICKYritethere is offline
intake manifold gasket sir, my poop starts up and idles down to 1500 after about 3 minutes. Hate driving like this, winter go away.
Old 01/16/2009, 02:04 PM   #6
eirek4
eirek4's Avatar
eirek4 is offline
not sure.. never had this happen before. the only thing I have done is the tb bypass.. so I was gonna swap it back seems how it got really cold past couple of days and change the manifold gasket too.. but it would idle surge from 1 to 2000 back and forth when in neutral or on the clutch.. just started doing it this morning.. no other issues before!!
Old 01/16/2009, 07:08 PM   #7
tken
tken's Avatar
tken is offline
does it do it when the car is warm or when its cold?
1994 honda civic cx hatch - SOLD
2000 honda civic ex - SOLD
1989 nissan 240sx - JUNKED
1988 toyota supra turbo - SOLD
2007 Yamaha YZF600R - SOLD
2004 Dodge Neon SRT-4 - DD
Old 01/21/2009, 03:44 PM   #8
eirek4
eirek4's Avatar
eirek4 is offline
it was doing it when the car warmed up.. but just happened when we had the freezing cold temps.. I had the coolant by pass through the throttle.. so I switched it back and it was running normal again on sunday and havn't had a problem since!!
Old 01/25/2009, 07:43 AM   #9
Dc2Ninjah
Dc2Ninjah's Avatar
fuck snow! ive scrtached my lip and exhaust cause of huge shit that falls off ppls mud guards.
Old 10/22/2009, 09:52 AM   #10
kung_lao_drifter
kung_lao_drifter is offline
Rsx's have automatic idlers, which means that you have a sensor either a temp sensor or vaccuum sensor that may be malfunctioning. Check your manifold air pressure readings right when it does it.
Old 02/02/2012, 10:55 PM   #11
shofury
shofury is offline
My car was doing it too, I think it was cuz of how cold it was because once it got nicer out like all this week was so far in iowa car has been idleing perfect but when it was cold it was surging all the way to 3,000 RPM warmed up and everything but now its fine
