Old 09/28/2009, 08:38 AM   #1
bukChans
bukChans's Avatar
bukChans is offline
Default ep3 strut replacement install help
I am working on replacing struts for a Ep3 03. when I got the strut out on both sides, am not able to push the axels back to align up with the bottom strut bolts of the new struts. It seems like the axel pop out of place. did I pull it out of place when i was taking the old struts out? Can anyone tell me if i did something wrong or how to correct this? desperate help. if anyone is very experience can you please advise. i have done a couple of cars without this issue.
Old 09/28/2009, 09:41 AM   #2
Hurricane_Hung
Hurricane_Hung's Avatar
Hurricane_Hung is offline
Default Re: ep3 strut replacement install help
its common on k engines.. just twist it around until it pops back in
03 rsx-s done for now
06 is250 daily grinder
Old 09/28/2009, 10:15 AM   #3
bukChans
bukChans's Avatar
bukChans is offline
so you are saying to keep spinning the rotors until the axel pops back in place? does it need to be push in while turning also? We tried doing that for almost 2 hrs and the car is still up on jacks as we speak.
Old 09/28/2009, 10:56 AM   #4
Hurricane_Hung
yea move it back and forth and push it in the same time and it'll pop back in place.
Old 09/28/2009, 10:59 AM   #5
bukChans
bukChans's Avatar
bukChans is offline
ill give it a try again. hopefully this works cause i am out of ideas for this car.
Old 09/28/2009, 12:32 PM   #6
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
ConHuevos! is offline
i went through this, lift the axle end up and forward towards your headlights. i remember doing this motion to get my axle back in place.
Sri Sri Ravi Shankar
Old 09/28/2009, 01:51 PM   #7
MJobe
*OG Member*
MJobe's Avatar
MJobe is offline
Give me 40 bucks , Ill finish it up . lol Easy stuff
-Out of the game
Old 09/28/2009, 02:31 PM   #8
bukChans
bukChans's Avatar
bukChans is offline
shit after what we have been through, the owner would probably not hestiate to give you 40 to finish it. i thought it was going to be cake walk also but never had the axels come out before. imma try to do what Randy (i think thats his name) advised. if that doesnt work, Jobe... you'll be hearing from me for a easy fix...
Old 09/28/2009, 02:44 PM   #9
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
Never underestimate a Mexican, Ive had this problem and I can fix it. Special Mexican price 38.99 lol
Old 09/28/2009, 03:41 PM   #10
bukChans
bukChans's Avatar
bukChans is offline
So Randy, how long did you have to mess wit it until it went in correctly... if your on the southside, i might need some supervision.
Old 09/28/2009, 03:56 PM   #11
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
Frustrated the fuck out of me for a good 20 minutes, it woulda cut down time if I woulda just asked for help right off the bat, took me and my bro around 5 min. To fix
sounds dirty but he pushed it up while I guided it in
Old 09/28/2009, 03:59 PM   #12
Wrench Re: ep3 strut replacement install help
Puerto Rican price $37.99 plus free sticker....
Old 09/28/2009, 04:01 PM   #13
We should all get a group of people together and show up at 9mm house......TEAM EFFORT to make sure that axel pops back in!!!
LOL
Old 09/28/2009, 04:03 PM   #14
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
Not even immigrants can get away from immigrant under cuts! And a free fucking sticker!! How am I supposed to compete with that.
Old 09/28/2009, 04:06 PM   #15
WELCOME TO THE U. S. of A. ....LOL Land of the under cuts........how 'bout we split it and I make you a sticker as well!!! LOL
Old 09/28/2009, 05:21 PM   #16
JustBrowsing
JustBrowsing's Avatar
JustBrowsing is offline
Should be a easy repair, I just dont understand what you are trying to describe? The axel just wont go into the knuckle?
Old 09/28/2009, 05:23 PM   #17
MJobe
*OG Member*
MJobe's Avatar
MJobe is offline
Shit! I was under-bid.
-Out of the game
Old 09/28/2009, 05:42 PM   #18
bukChans
bukChans's Avatar
bukChans is offline
importsusa... you got mail... i sent you a picture of the rotors and strut... it will not move up for me to align the two bottom strut bolts. still not having luck with your suggestion.
Old 09/28/2009, 07:26 PM   #19
MJobe
*OG Member*
MJobe's Avatar
MJobe is offline
Mount the shock on the shock tower (3 bolts) then I assume you already have the lower ball joint & knuckle set on to the lower sub frame?
Obviously you need to allign the axle into the knuckle, so it will slide in the spline when connecting the knuckle to the strut.
When connecting the strut and knuckle, Have a friend push down on the rotor as hard as he can so you can put the 2 bolts in to connect the strut and knuckle. BOOM your done.
Where are you located? I will come help if you absolutly need it. But it is a Pita, I just did my girlfriends 02 civic last week.
-Out of the game
Old 09/28/2009, 07:34 PM   #20
RICKYritethere
Work
RICKYritethere's Avatar
RICKYritethere is offline
Mikes got it.
Old 09/28/2009, 07:38 PM   #21
Yeah, I got the picture.....my suggestion probably didn't work, because I never made one yet....LOL It was CON HUEVOS that suggested.....LOL
All I did was under bid CON HUEVOS and MJOBE......Puerto Rican style...
Old 09/28/2009, 07:40 PM   #22
THAT WAS WORTH $40.00 dollars to me!!! LOL
Old 09/28/2009, 09:43 PM   #23
bukChans
bukChans's Avatar
bukChans is offline
yeah the axel came off of the spindal if thats is what you call it... so we had to take the axel out and realigned it. we finally got it but it shouldnt have been 2 day job just for struts. i shouldve came here.. but any takers to tackel a up/downpipe on a subie once i get it since you guys know you stuff...? i got a case and some bombass grill chicken wings on it
Old 09/28/2009, 10:02 PM   #24
MJobe
*OG Member*
MJobe's Avatar
MJobe is offline
I accept PayPal.
Glad you got it done.
-Out of the game
Old 09/29/2009, 09:13 AM   #25
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
you had me sold @ chicken wings
