Old 10/28/2009, 08:25 PM   #1
jsongkhamdet
jsongkhamdet's Avatar
jsongkhamdet is offline
Default Help Please
My car studders at vtec or when i get into full boost around 4500-5000 rpms...happend out of nowhere...changed out the spark plugs still doesnt fix the problem...the setup is a boosted jdm gs-r (b18c)...any suggestions?? call/text 641-352-9239 thanks!
Old 10/28/2009, 08:57 PM   #2
jsongkhamdet
Default Re: Help Please
Old 10/28/2009, 09:51 PM   #3
Originally Posted by jsongkhamdet View Post
Have you checked your spark plug wires to see if they have any type of burn marks around the ends going into the spark plugs. Obviously this is a shot in the dark, but checking that also may be a possibility. If theres a burn mark or crack on any of the wires, it'll make the spark arc right to the walls around it.....possibly causing your problem. Start with that and keep posting more problems as they come............remember it is very hard to diagnose your car through the internet. All we can do is suggest possibilities!!
Old 10/28/2009, 10:16 PM   #4
jsongkhamdet
well i recently changed my spark plugs and gapped all the plugs to .025-.030...pulled every plug from every cylinder to see if i was gettin a good spark...still seem to have the same problem...i do have a msd 6AL ignition control,msd blaster coil,msd 8mm spark plug wires...
Old 10/28/2009, 10:39 PM   #5
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
boost leak would be my guess
Old 10/28/2009, 10:43 PM   #6
jsongkhamdet
that could be the problem...my have a vacume leak somewhere i believe cuz my boost gauge reads around 15 instead of 20 like it use too...
Old 10/28/2009, 10:45 PM   #7
jsongkhamdet
but would that cause me to cut out at 4500-5000 rpm??
Old 10/28/2009, 10:46 PM   #8
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
does it like stutter and then at higher rpms even back out smooth?
Old 10/28/2009, 10:58 PM   #9
jsongkhamdet
its stutters and doesnt even let me go past 4500-5000 rpm
Old 10/28/2009, 10:59 PM   #10
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
so the rmps stop at 4500-5000 and it wont let you go above that. so it acts like thats the red line? if so your ecu is in limp mode
Old 10/28/2009, 11:05 PM   #11
jsongkhamdet
what caused my ecu to go into limp mode?? im running a chipped p72 (94 gsr)
Old 10/28/2009, 11:10 PM   #12
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
it could be a number of thigs. crank position sensor, knock sensor,its just a game of looking over everything. try to un-hook your battery for like 5-10 mins, this will clear the ecu, like if a check engine light is on, it will re-set it, and take it out on the street and go full throttle, and see if it does it. if it does, then its in limp mode, and you just have to check everything out to make sure something didnt come un plugged. did you get your car tuned by any shop?
Old 10/28/2009, 11:19 PM   #13
jsongkhamdet
My car is running code 8 which is the TDC sensor (top dead center) but its always been on and ive never had this problem...unplugged the batter to reset the ecu still having the same problem and the CEL is still on...my car was tuned in minneapolis.
Old 10/28/2009, 11:21 PM   #14
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
what is it tuned on? if anything i would take it some where and have them look at the ecu and the tune and tell you if anythings wrong
Old 10/28/2009, 11:24 PM   #15
jsongkhamdet
itz tuned with chrome...cars been tuned for a while now and ive never had this problem before...it jus happend out of nowhere...if i was in limp mode wouldnt i be throwing a code??
Old 10/28/2009, 11:25 PM   #16
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
i would imagine. if its throwing the TDC sensor, i would replace it and then take it to a guy or a shop. do you still live where you go it tuned?
Old 10/28/2009, 11:26 PM   #17
jsongkhamdet
Pm'd
Old 10/28/2009, 11:33 PM   #18
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
replied
Old 10/28/2009, 11:40 PM   #19
jsongkhamdet
soo i found out that my ECU is defintaly in LIMP MODE...anyone have any ideas??
Old 10/29/2009, 12:20 AM   #20
jsongkhamdet
im throwing code 8 which is tdc sensor (top dead center) could this be the cause that im running in LIMP MODE??
Old 10/29/2009, 12:06 PM   #21
jsongkhamdet
anyone with any suggestions??
Old 10/29/2009, 01:56 PM   #22
jsongkhamdet
Bump
Old 10/29/2009, 02:21 PM   #23
PM'd ya man....reply to the PM when ever you get a chance.
Old 10/29/2009, 02:28 PM   #24
jsongkhamdet
Replied...thanks
Old 10/29/2009, 08:12 PM   #25
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
just let me know if the dizzy thing works, if not my friend will come look at it
