Old 10/29/2009, 08:25 PM   #26
jsongkhamdet
jsongkhamdet's Avatar
jsongkhamdet is offline
Default Re: Help Please
ill let you kno...thanks alot man!
Old 10/30/2009, 01:32 AM   #27
seandm
seandm's Avatar
seandm is offline
hey my buddy dsmtsi tunes, you can probably have him look at your car to see if its somthing in the tune that is causing it to that.
lmk 515 480 3061
Old 11/02/2009, 01:07 PM   #28
turborex
turborex's Avatar
turborex is offline
are you sure your not getting fuel cut off. when it goes to limp mode you must have been getting on it. check your oil level, and change out your voltage to your dizzy, it could be a shot Ignition coil. they got limp mode and survival mode on these hondas
Old 11/06/2009, 10:31 AM   #29
Map sensor might cause this as well.
Old 11/07/2009, 01:32 AM   #30
jetlag
jetlag is offline
sounds like your tdc sesor is bad (better known as crank postion sensor). Did you fill the car up with some lower octane fuel? cps could read fluctuations in crank speed (aka missfire)
http://img.photobucket.com/albums/v8.../107215784.gif
http://img.photobucket.com/albums/v8.../111902476.gif
Flow chart on how to diagnose the problem. idk if thats for sohc or dohc but Im willing to bet its basically the same.
Also in my opinion id get rid of that msd stuff except for the wires and maybe the blaster packs. 6al box is not needed. hondas ignitions are pretty strong
Old 11/20/2009, 08:07 PM   #31
I was just thinking MSD Box. If you go to MSD's webpage they will tell you how to check the box. Got an AE86 in the shop right now and it has the 6AL and it was bad. However, not sure if the box is bad it may not even start but it is one more thing that should be checked.
Also it could be spark blow out...you said it was boosted right. Try gapping the plugs a little tighter. We gap them around .18-.20 and use regular NGK plugs. Got the part number here at the shop that we have found good luck with in boosted hondas.
I also agree with getting rid of the MSD box. Took it out of my GSX and put in a Kenne Bell Boost a Spark.....solved my problem.
Keep us updated.
Old 11/23/2009, 05:02 PM   #32
Keep us updated.
I'm still a believer in MSD, however I do know that they can be picky on where you route the wires, as can anything electronic of course. I chased down a misfire for quite some time and finally figured out that the dizzy wires were too close to the coil wire and causing interference/misfires in higher rpm's.
www.roskoracing.com
Old 11/24/2009, 02:29 PM   #33
Yea, wiring the MSD needs to be right. Check your instructions. I'm pretty sure it should be grounded directly to the battery.
That's what we found on that AE86 Corolla.....MSD box wasn't wired right.
