Old 11/30/2009, 11:51 PM   #1
Timmyflys
Timmyflys's Avatar
Timmyflys is offline
Default ls vtec problems
alright my idle is a little high. there is a nipple right underneath the intake manifold its a stock gsr intake manifold. i have looked at all the vacumm diagrams and coolant and shit. i can't find it anywhere. if anyone has a gsr that could maybe take a look or if someone knows or has a better diagram that would be sweet.
also i believe its a ob0 ls block has the canister in the block with the pcv valve in it. where do i need to run that too. i keep reading up something about people drilling a hold in there valve covers for it. is that my only option. gotta be some other way.
mite be some other questions i have. please keep chimin in and help me get this thing runnin good. any mtown peeps wanna stop by and help out that be cool to.
thanks.
Old 12/01/2009, 08:48 AM   #2
91da
JDM BALLER
91da's Avatar
91da is offline
Default Re: ls vtec problems
There is a canister that one end plugs into than the other end plugs in the the intake mani.
91 Acura Integra Dohc Vtec
94 Honda Civic EX Sohc Vtec
95 Honda Civic CX H22
07 Honda Civic SI K20 Vtec
07 GMC Denali
74 Monte Carlo Figure 8 car
Old 12/01/2009, 12:48 PM   #3
Timmyflys
Timmyflys's Avatar
where on the intake manifold.
i put the hose from the pcv valve on the intake mani where the nipple is right under the manifold and i think its puttn oil into the manifold. cuz its funky when it starts. but then it runs good.
Old 12/06/2009, 10:38 AM   #4
that is just a dump I wouldnt run it back into your motor unless you like hot blow by oil going back into your intake manifold :thumbsdow: also it is prolly making your car idle like shnit ... id just have the one hooked up (prolly already is) and just leave the other one venting .....
