Go Back   JDMCITY.COM > Technical Forum > Interior Design
Old 06/26/2012, 05:05 AM   #1
integrals
integrals's Avatar
integrals is offline
Default Wet sanding
Hey guys I just finished up painting my car and am about to start sanding clear coat and I want to get a little more info on it to make sure I don't do sOmethong the wrong way. So my questions are do you guys run a hose on the car the whole time or just dump the paper in a bucket , how much do you spend on each panel and how do you know your good on thAt panel. Thank you for your help
96 EJ6 with 00 front end
99 Lifted Silverado- Yard deceration
94 EJ1-traded for current
93 integra boosted-sold
Old 06/26/2012, 02:35 PM   #2
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
XCLUZIVEAUTOWRKZ's Avatar
XCLUZIVEAUTOWRKZ is offline
Default Re: Wet sanding
easiest and fastest way is with a DA and a spray bottle 1200, 1500, 3000 trizac pads. and will buf out REAALLLL NICE
just be very carefull around edges and body lines until you are real comfortable with it.
WE DO IT ALL, FROM PAINT TO FIBERGLASS, FRAME SECTIONING TO LIFTS, CONVERSIONS TO VERTICAL DOORS..
http://www.XCLUZIVEAUTOWORKZ.COM
Old 06/26/2012, 06:10 PM   #3
Pancho
Pancho's Avatar
Pancho is offline
How many coats of clear you put on it?? Sanding clear with water should make it kinda foamy.. thats when you know your done with that area
92 Civic Hatch SI [Sold]
92 Talon Tsi AWD[Sold]
93 Civic Hatch SI [Sold]
Old 06/27/2012, 07:56 AM   #4
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
doesnt necessarily mean your done, your done when you get it as flat as you want it. it will foam up way before you get all the orange peel out.. and the 3000 grit trizac pads will foam up the whole time your sanding.
Old 06/27/2012, 10:25 AM   #5
austing64
austing64's Avatar
austing64 is offline
he's right. just do like exclusive said and it be good just watch edges with the 1200 and 1500. the 3000 you can sand for awhile before it hurts anything 3000 is almost like a pre-buff on the 1500
"you like my new car huh? lick your lips, slut."
07'STi
93'BMW 318is
84'"355 cid" S-10
01'Yamaha R1
Old 07/03/2012, 04:46 PM   #6
integrals
integrals's Avatar
i have about 3 or 4 good coats on and alright what do you mean by foamy ive heard it will look dull/ very blurry after you do it then once you buff it will turn shiny again
Old 07/03/2012, 05:53 PM   #7
Pancho
Pancho's Avatar
Pancho is offline
Yea it will turn very dull.. once its all like that.. you ready to buff
Old 07/03/2012, 08:52 PM   #8
integrals
integrals's Avatar
alright i was getting worried ha thanks man
Old 07/03/2012, 10:55 PM   #9
Pancho
Pancho's Avatar
Pancho is offline
You couldve also put some rubbing compound on a rag and rub it around there just to make sure
Old 07/05/2012, 07:20 AM   #10
Bmwz389
Bmwz389's Avatar
Bmwz389 is offline
If you want it to turn out straight as it can be, you need to block it, not use a dual action sander. You can put all kinds of dips and waves in the body panels with a DA.
Blocking is the only way to go.
I did 4 rounds of block sanding the finish coat on my 87 Monte and she came out straight as an arrow. Of course, I had 400 hours of body time in it by the time it was all said and done lol.
- Brandon
Old 07/05/2012, 10:37 AM   #11
Pancho
Pancho's Avatar
Pancho is offline
I would say blocking is for primer.. thats where you want to get it straight as possible.. clear coat is not meant to fix any blocking imperfections.. and your using 1500-3000 grit paper so its not gonna dig too much if your moving it around with low air pressure
Old 07/05/2012, 10:46 AM   #12
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
blocking is for primer??? blocking is for everything if you want the reflection like glass.( you just use a different kind of block for wet sanding clear). which is is usually for show cars AND which is why i recommended the DA ,but i guess your the pro here.. lol
listen to mr pancho..
Old 07/05/2012, 01:17 PM   #13
Pancho
Pancho's Avatar
Pancho is offline
i would use the DA also.. but i guess im done here.. good luck on your car
