Old 04/06/2011, 09:45 PM   #1
alexbuck205
alexbuck205's Avatar
alexbuck205 is offline
Default loss of boost
got my car tuned at wrenches on sat and was tuned at 12lbs
couple days later the bolts rattled out of the wastegate that holds it to the turbo so it opened up the screamer pipe.. i bolted it back up and noticed i'm only boosting 6lbs now.. checks for boost leaks and there are non.. not sure what my problem is.
05 CBR 1000RR REPSOL
07 Acura TL-S
Old 04/07/2011, 07:31 AM   #2
jared50438
jared50438's Avatar
jared50438 is offline
Default Re: loss of boost
bad wastegate gaskets... or check couplers, turbo to manifold can you hear or smell exhaust when idling or not in boost.
2002 sebring silver s2000
inlinepro kit w/gt35r
r200 diff kit
http://www.jdmcity.com/showthread.ph...361#post221361
1997 TYPE R Cloneish
build http://jdmcity.com/showthread.php?t=15798
'93 civic vx g23 12:1 e85
Old 04/07/2011, 03:28 PM   #3
Tommy
Tommy is offline
Check all vacume lines too.
Old 04/07/2011, 07:23 PM   #4
kornfedb20
kornfedb20's Avatar
kornfedb20 is offline
sounds like something with the wastegate check and make sure your wastegate didnt get messed up some how you never know.
Old 04/08/2011, 07:33 PM   #5
alexbuck205
i found 2 boost leaks today fixed them and took off the ebay bov and put a pit one on and still only 6lbs so idk what the hell is wrong. i have an external wastegate i just need a 12lb spring so where can i get one?
07 Acura TL-S
Old 04/11/2011, 07:47 AM   #6
pirate
pirate's Avatar
pirate is offline
clutch sliping (this would have to be pretty extreme)?
if theres no leas, perhaps ring are fried, does it hold the 6 lbs, or reach 6 lbs and bleed down?
whats your afrs look like at wot?
oh wait, you dont have a wb.. ; )
any noticeable difference in the vac reading at idle?
EGT numbers differ from when you got tuned?
www.facebook.com/syn-customs
Old 03/10/2013, 01:33 PM   #7
unplug the wastegate and see what happens, you running a boost controller?
o wow just looked at date on this my bad
