Old 04/12/2010, 09:54 PM   #176
jdmb18hatch
Retired
jdmb18hatch's Avatar
jdmb18hatch is offline
Default Re: What did you do to your civic today?
Originally Posted by Dj Technick View Post
Ordered some RC injectors today, looking at different headers right now...thinking bisimoto...Try to get it tuned sometime in may...then go shopping for some cams...just not sure what cams to get
Um, might wanna get cams BEFORE you tune....
Old 04/13/2010, 01:38 AM   #177
Good point there Ryan. I think I figured out the problem in my car.
Somebody put a prelude engine and an integra tranny into a CIVIC??!! What is wrong with people these days?
Seriously though, I got everything pulled apart tonight and I am trying to run down my oil issue.
Mike
DC hawtness!!!! Modified like it should have been from DC......
Old 04/13/2010, 07:57 AM   #178
gabebauman
DR. DIY
gabebauman's Avatar
gabebauman is offline
LOL
So Mike...did you do the collector modification yourself? I use to have a DC Ceramic 4-2-1 header on my old D16Y8, (it's actually still runnin' strong in Ric Johnson son's hatch) but anyway. Would my B20B benefit more from a 4-2-1 or 4-1 header? I had 4-1 ebay on my B20Z2 in the red dragon.
Old 04/13/2010, 08:39 AM   #179
blacksheep
blacksheep's Avatar
blacksheep is offline
Gabe - From what I have read 4-2-1 sacrifices some top end to give you the mid-range torque. The 4-1 is better for top end. The 2.5" collector mod and its variants I think help high compression engines breathe better up top. For auto-x and what you are doing, I would stick to 4-2-1, but thats just me.
Old 04/13/2010, 09:00 AM   #180
Gabe, I did all of the modification short of the welding myself. I had Chris (MR2) do the welding for me. Amazing work with the TIG. I cut back to the largest point I could get a section of 2.5" round tubing around it, then took a piece of SS 2.5", heated it as hot as I could and used a 2x4 and 3lb sledge to force it to oval around the shortened collector. After I did that, I again removed some more of the old DC collector and then took it to Chris for the welding. Since this was going on an H2B setup, I needed to remove some radius from the bend in the B-Pipe. The H22 tilts forward when attached to the B-Series trans as compared to when it is mated to an H-Series trans it tilts back. So Chris welded the radiused B-Pipe back together and also welded on my 2.5" collector. From there I was hooking up to a 2.5" Greddy SP system for my coupe. I needed to extend it and put in a flex section since I removed that from the DC. This is where I deceided to go a little more high tech. I had Chris put a V-Band on the end of the header, then terminate both ends of my extension (w/ flex pipe) with V-Bands, as well as terminate the start of the rest of the exhaust with a V-Band. Very solid connection as far as sealing, never have to worry about gaskets and bolts wearing out or getting loose. I would highly recommend it if you have the time and patience.
As far as your setup is concerned, go with the 4-2-1. It will be the better header for your powerband and desired use of the car. When it comes to B-Series headers, go back 10 years in a mag like SCC and look at some dyno shootouts. Should give you a good one to buy.
Mike
Old 04/13/2010, 09:06 AM   #181
gabebauman
DR. DIY
gabebauman's Avatar
Thanks KC and Mike.
Old 04/13/2010, 10:17 AM   #182
blacksheep
blacksheep's Avatar
Mike
Mikey - You sure the Greddy SP is 2.5" ID (or OD for that matter)? I thought only Greddy Evo was 2.5". I thought Greddy SP was like Apexi WS2 and is 2.36".
Old 04/13/2010, 10:39 AM   #183
It has a 2.5" v-band clamp on it. I know that much. I was amazed that it was that size when I picked it up used originally. It is an original SP, not that SP2 crap either. Loved that exhaust on my prelude, who would have thought I would find one for the civic.
Mike
Old 04/17/2010, 12:20 AM   #184
Found another thing that I need to buy...looks like it's gonna be a while before she is up and runnin. Plus RC called and they have some crazy back order going on with there injectors, so it looks like im gonna be buying cams sooner than I thought. Still not sure which ones I want tho...
Old 04/17/2010, 12:23 AM   #185
Mike
Whats wrong with H2B?
Old 04/19/2010, 04:56 PM   #186
cleaned throttle body... nasty as f*ck... but idles at night and morning.. not sure if its the iac sensor that needs to be cleaned or the map..
Old 04/20/2010, 02:16 PM   #187
Oil control rings that I got from Race Engineering were not proper size for the JE Pistons that are in it. I had oil burning issues, and that is what it boiled down to. I will be ordering new rings here in the upcoming weeks. After I get those in, it should be going back together.
I just picked up my new daily driver from PA this past weekend. Drove it all the way home (966 miles) on a bad headgasket. I didn't have any overheating issues, and it only used a little bit of oil. Definitely a bad HG though, as I did a compression test this morning, and it read 150/60/30/60 I had a little bit of oil mixing with the coolant that bubbled to the top of the radiator, but other than starting hard, it has not had any issues. I will be starting on the HG today most likely. Should be some fun there. 264,000 miles, original clutch, and on its second timing belt. This car is a champ.
Mike
Old 04/20/2010, 04:29 PM   #188
Cyberwaste
LURKIN
Cyberwaste's Avatar
Cyberwaste is offline
what is your new DD??
http://imgur.com/N3ABL
Old 04/21/2010, 12:26 PM   #189
Just ordered some cams from Bisimoto this morning. Also ordered a fuel rail from AEM. Now all I got left to buy is a header...got to save up for this one bisi's headers aren't cheep.
Old 04/21/2010, 05:35 PM   #190
98 LX Sedan
Old 04/21/2010, 06:34 PM   #191
jared50438
jared50438's Avatar
jared50438 is offline
got my g23 up and driving been driving her around! low end torque feels clean engine runs strong too! recieved my vis carbon fiber hood today also! new bumper coming too. hids are wired up interior is back in and the heat works :D
have to bleed the brakes some more.
and thinking about getting the password jdm carbon intake too!
2002 sebring silver s2000
inlinepro kit w/gt35r
r200 diff kit
http://www.jdmcity.com/showthread.ph...361#post221361
1997 TYPE R Cloneish
build http://jdmcity.com/showthread.php?t=15798
'93 civic vx g23 12:1 e85
Old 04/21/2010, 06:42 PM   #192
the whale penis intake ?
Old 04/22/2010, 10:24 AM   #193
jared50438
jared50438's Avatar
ya it will over the cables for the h22 tranny, and clean it up nice. little too pricey though.
r200 diff kit
Old 04/23/2010, 07:52 PM   #194
Midwesteeze
Midwesteeze's Avatar
Midwesteeze is offline
installed front suspension, finshed taking the hood down to bare metal, hood raise, and a gool ol rain wash
Old 04/25/2010, 10:22 AM   #195
blacked out my taillights yesterday. left the reverse clear.... looks raww as f*ck!!!
will post pics soon.
Old 04/25/2010, 10:33 AM   #196
jared50438
jared50438's Avatar
installed my carbon fiber hood and aerocatch latches.
looking for an oem bumper
r200 diff kit
Old 04/25/2010, 10:56 AM   #197
http://cgi.ebay.com/ebaymotors/PASSW...Q5fAccessories
200 inst to bad considerging a aem v2 cost like 279
Old 05/01/2010, 01:24 AM   #198
did the corner lights and front lip today... my car was low on oil
bleed the brakes.. friday got my new rotors and pads installed..
i have an idle problem, cleaned my throttle w/ new gasket, and ran better but idles roughly at night or early morning.. not sure if its iac sensor going out.
Old 05/01/2010, 02:44 AM   #199
Cyberwaste
LURKIN
Cyberwaste's Avatar
clean iacv it may help and what kinda idle prob?
Old 05/02/2010, 01:56 AM   #200
I'm not sure how to describe the idle. at a cold temp, it idles about 800 to 1200 or so back and forth...
I didn't know if i had to clean the iac sensor straight through.. i bolt it out and it has a screen and a tunnel goin towards the solenoid..
