Closed Thread
Old 08/05/2010, 11:02 PM   #1
Dat1BVtecN
Dat1BVtecN's Avatar
Dat1BVtecN is offline
Default 95 Accord LX problem! gauges, windows..HELP!
All my gauges are out and the windows are stuck. The car drives fine however in every gear.
Rpm and speedometer gauges went out ....then I stopped and put the car in park.....then I turned the car back on and it wouldnt come out of park........i finally pushed in the shift lock key and got it into drive but the gauges were still messed up. Does anyone have any idea of what is causing this problem? Need HELP ASAP!
Checked all fuses under the hood and none are blown. I cant check the fuses under the dash at the moment cause its dark out, no flashlight and not close to home. Any HELP FAST WOULD BE GREAT! Thank you!
OOOO 3.2 AWD
Old 08/05/2010, 11:32 PM   #2
SykoFerret
SykoFerret's Avatar
SykoFerret is offline
Default Re: 95 Accord LX problem! gauges, windows..HELP!
My best guess would be Interior fuses, Main Relay, ECU in that order... Or try disconnecting the negative battery cable for 10+ seconds to reset the ecu... I'm no mechanic, but that's where I would start. Let me know what works though... (I learn as I go)
...Yeah, I'm a geek. EPIC FAIL http://www.youtube.com/watch?v=6rOiOjxZonY
Old 08/06/2010, 12:20 AM   #3
Dat1BVtecN
Dat1BVtecN's Avatar
I'll check that first thing tomorrow. Any other suggestions would be appreciated!
OOOO 3.2 AWD
Old 08/06/2010, 11:59 AM   #4
Dat1BVtecN
Dat1BVtecN's Avatar
no one eh..
OOOO 3.2 AWD
Old 08/06/2010, 07:30 PM   #5
94integraguy
94integraguy is offline
I use to have a 94 accord and when i did my swap in it i forgot to bolt down the ground on the tranny and it was loose and it made all my stuff act up like that u should try that.
Old 08/08/2010, 04:44 PM   #6
93CB7Tuner
93CB7Tuner's Avatar
93CB7Tuner is offline
What do you mean by the gauges are out? it's not working or the lights are out?
and your window's won't roll up?
Closed Thread
