Go Back   JDMCITY.COM > Manufacturer Forum > Other Manufacturer Forum
Old 05/27/2011, 06:00 PM   #1
nixholas
nixholas's Avatar
nixholas is offline
Default My Bimmer
My 1988 BMW 325is (updated 8/14/2013):
Aesthetics/Interior:
Lamin-X Film on headlights (Yellow High's, Clear Low's)
DIY Euro Grilles
Inverted Volvo Lip
XXR 521: 16x8 ET25
Momo Corse Steering Wheel
Momo SuperAnitomico Shift knob (With ///M stripes)
SRD/Speed Knockoff Seats (these things are junk!)
VDO Mechanical Boost Gauge (off manifold)
Underbody:
H&R Cup Kit
DIY .5" spring spacers in the rear
BMW Z3 Steering Rack (now 2.7:1 vs 4.0:1 stock)
Ireland Engineering 25mm Front Bar
Ireland Engineering 22mm Rear Bar (currently on car but disconnected)
Rear Camber/Toe Adjustment Kit
Revshift 95A Polyurethane Rear Trailing arm Bushings
Revshift 95A Polyurethane Rear Subframe Lift Bushings
Stainless Braided Brake Hoses
Drivetrain:
Chromoly Lightened Flywheel
6-Puck MIBA Race Clutch
Heavy Duty Pressure Plate
SSK with DIY derlin bushings.
Revshift 95A Polyurethane Differential Bushing and Spacers.
Revshift 95A Polyurethane Motor and Transmission Mounts
Engine/Management:
Stock M20B25 w/ 130k (Original engine blew head gasket at 290k)
30lb GM SC 3800 Injectors
Stainless Turbo Header
Turbonetics T3/T04e hybrid, .57 trim compressor, Stage 3 turbine wheel, .63 exhaust housing, Internally gated
Custom downpipe to open exhaust
RS type knockoff BOV
Generic 27x5x2.5 Bar/Plate Intercooler
Mechanical Fan Delete
Welded Aluminum Radiator
Custom remote oil filter
14point7 SLCDIY1 Wideband Controller
Moates Ostrich 2.0 ROM Emulator with address hit tracing.
Ford hot-wire-type MAF
Yet To Be Installed:
Revshift 95A Polyurethane Front Control Arm Bushings
Old 05/27/2011, 08:55 PM   #2
Default Re: My Bimmer
I'm reallY really really LOVIN' this car.........I love the color as well (Red is my favorite color)........we have another member in here from Omaha that has one that would love to do a feature on your car. He does a blog/magazine style feature on all types of cars..........yours would definately be in there.
Glad you joined our forum man........we need more diversity in vehicle brands, this is a PERFECT example. Never got a chance to work on a Bimmer until Nate brought his in.....only problem I had in wanting to do his clutch was what he stated before (rusted bolts on manifold). Everything on that car would have taken me a LONG time to get done and with running a business I just couldn't do that. So I opted for him to just take it back and have him take theengine out to make light work of it. Only thing I got to do was put on his suspension and fix a little electrical issue I really wanted to do the clutch on it but too many factors were against me.
Maybe someday I will get to work on one for sure...............these older models and the newer ones ALWAYS capture my attention. Good luck with everything you do with this car now and in the future.........
Old 05/27/2011, 11:06 PM   #3
nixholas
nixholas's Avatar
nixholas is offline
Thanks man :)
Well, you can work on mine if you like ;) It needs a lot of help... The car's not bad, but it's not great either.
Old 05/29/2011, 12:04 AM   #4
crvtec54
crvtec54's Avatar
crvtec54 is offline
that is awesome! quite a machine. now it just need to be about 2-3 inches lower i love slammed bmws.
Old 05/29/2011, 02:31 PM   #5
nixholas
nixholas's Avatar
nixholas is offline
The Cup Kit gave it a 2" drop... I didnt like the wheel tuck in back, so I made some spring spacers. I'll probably switch to some fully adjustable coilovers eventually, but I'm very happy with the current ride height.
The thing it desperately needs right now is tires and the rear camber/toe adjustment kit.
I'd like to get the camber/toe kit first to keep from destroying a new set of tires.... But my current tires just started showing cords, not sure if I can wait.
Old 05/29/2011, 02:53 PM   #6
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
ha probably should get those changed asap. i had a semi flash me on the interstate and when i pulled over he was like hey there are sparks shooting out from underneath your car lol
i put some racelands on my e36 but i haven't got to drive on them or adjust them to where i want them yet.
1999 Ford Expedition
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 05/29/2011, 03:03 PM   #7
nixholas
nixholas's Avatar
nixholas is offline
Trying to get up to 25 posts so I can post a wanted ad for some used tires.
Old 05/30/2011, 02:18 PM   #8
Lee_MA61
Lee_MA61 is offline
That's a nice car, I like it a lot. E30s are my favorite style of bmws. I'm guess you aren't running a whole lot of boost? that's judging by those 19lb injectors.
-1984 Toyota, Celica Supra P-Type Super Red (2JZ-GTE + 74mm)
-1985 Toyota, Celica Supra P-Type Super Silver (no engine...)
Old 05/31/2011, 12:03 AM   #9
nixholas
nixholas's Avatar
nixholas is offline
LOL, yeah. I'm running 6psi, not planning to push it much further unless the engine gets rebuilt. The car is great fun right now, I don't really need anymore power.
Most people will say: "why spend all that money on turbocharging the car when you could have made the same power NA for less" But they don't realize that to increase the horsepower by ~40% on a motor that has ~225k without Forced Induction would have required a complete rebuild to start with, speccing a large cam, increased compression ratio and all the same engine management stuff I have now... That would have cost around $2000. I'm at $900~$1100 right now... I've gotten a great bargain :)
Old 06/01/2011, 02:43 PM   #10
blacksheep
blacksheep's Avatar
blacksheep is offline
Is this pic on Quebec St in Ames? I believe I lived in the house with garage to the right of the bmw when I went to college there....LOL My galant vr4 spent most of its time in that garage...
Old 06/01/2011, 03:45 PM   #11
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
the difference being you will have to do that stuff later on anyway but the boost will make it happen sooner haha
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 06/01/2011, 04:04 PM   #12
nixholas
nixholas's Avatar
nixholas is offline
Yeah, that's right.
That's true, but with an engine build 12-15psi isn't out of the question... Then we're talking ~325-350hp (probably more than that with a displacement increase and turbo specific cam grind).
Old 06/01/2011, 05:13 PM   #13
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
i'd love to get an AA SC kit for my E36. 300hp/300tq. M50 ftw
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 06/21/2011, 09:59 PM   #14
windySI
windySI's Avatar
windySI is offline
You should bring this to european motors sometime, I work there and im sure I wouldnt be the only one who would appreciate it
Speed provides the one genuinely modern pleasure. - Aldous Huxley
Old 06/27/2011, 03:59 PM   #15
nixholas
nixholas's Avatar
nixholas is offline
Sure thing, where is european motors??
Old 06/29/2011, 11:47 AM   #16
damn that is impressive for a built under $1000 nice car, i like those bmw alot
Old 06/30/2011, 08:50 PM   #17
windySI
windySI's Avatar
windySI is offline
http://maps.google.com/maps?oe=utf-8...e&ved=0CAQQtgM
Come in and get an oil change or something
Old 07/11/2011, 10:52 PM   #18
turbob20vtecciv
turbob20vtecciv's Avatar
turbob20vtecciv is offline
For having just a stack in that thing, its an awesome setup
'01 Lexus IS300, DD
'74 Datsun 260Z Work in progress
'97 Civic Coupe Turbo B20 vtec, Money pit
Old 07/28/2011, 02:13 AM   #19
nick88
nick88 is offline
this thing is sweet, i want one.. lol
Old 01/09/2013, 10:40 PM   #20
cdcEGcivic
cdcEGcivic's Avatar
cdcEGcivic is offline
ive seen this thing run autocross at marshalltown once or twice... one badass little machine!
Old 02/18/2013, 12:13 AM   #21
Cakija
Cakija is offline
in love <3 your cars amazing
Old 08/14/2013, 03:48 PM   #22
nixholas
nixholas's Avatar
nixholas is offline
Wow, I have been off this forum for a long time! I came to post a want ad for some rims (to put a set of r-comps on), and I thought I'd look at this. Sorry to everyone who has posted in the last two years!
