Old 09/15/2011, 11:37 AM   #1
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
XCLUZIVEAUTOWRKZ's Avatar
XCLUZIVEAUTOWRKZ is offline
Default REMOTE STARTS!! and ALARM COMBOS
Its that time of year guys, Getting cold......Already. Time to get in and get a remote start installed. Dont get stuck having o run outside in the cold, the snow to start your car to warm it up in the morning.... UNLESS you like doing that.. then lol..
Here are some pricing on different options we have.. All prices include install which will include door locks, trunk pop, shock sensor(if alarm/RS unit), Horn if wanted, and parking lights.. Alot of shops charge extra for that stuff, That is included with our basic install..So if you have power locks or power trunk pop.. They WILL be hooked up..
Extras charges on top of listed pricing would be,
-Bypass module(if you have a chipped key etc)
-added sensors (motion sensors, window roll up modules etc. for alarm combo units)
-or misc stuff like Lock relays (for certain vehicles)
ALL UNITS BOUGHT/INSTALLED FROM US WILL HAVE A FULL WARRANTY ON UNIT AND PYTHON ALARM/COMBO UNITS WILL HAVE THE DIRECTED $2500 GUARANTEE
PYTHON PRICING
REMOTE START/ ALARM COMBO UNITS
$725.00
PYTHON 592
Responder HD Color SuperCode SST 2-Way Security and Remote Start System
NEW! Responder HD features Python's most advanced color remote, operating a one-mile range, 2-Way security and remote start system with an upgraded user interface, mini-USB charging port and patented menu wheel.
* One Mile Range with SST
* Neo Revenger Soft-Chirp 6-Tone Siren
* 4 Auxiliary Outputs Channels for Optional Functions
* Fail-Safe Starter Kill
* Dome Light Supervision
* Guaranteed Protection Plan (GPP)
* One Responder HD Color SuperCode 2-Way and One 5-Button 1-Way
* Onboard Stinger Double-Guard remote-adjustable shock sensor
__________________________________________________ ________________________
$525.00
NEW! Python 991 with 2-Way Responder LC3 SuperCode™ SST Remote.
Featuring One Mile Range with SST, Python's third-generation liquid-crystal display remote control is the slimmest display remote available! Key features include:
* Priority™ user interface and icon map
* Priority 5-button user interface
* Remote can confirm commands with tones, vibration, text and icon display
* Remote notifies of security intrusions with tones, vibration, text and icon display
* Powerful lithium-ion rechargeable battery with mini-USB charging
* Integrated text display
* Tone, vibe and display notifications and confirmations
* Active Temp Check – displays internal cabin temp while remote start engaged
* SilentMode2 – alerts of intrusions without vehicle siren or light activation
$425
PYTHON 872
Responder™ LE 2-Way Security System / Remote Start System
Features
* Revenger® Six-Tone Siren
* Confirms commands and system triggers with flashing LEDs
* Built-in Turbo Timer
* Horn Honk
* 24 channel remote start / security / keyless entry system
* Comfort Closure
* Includes One LED 2-Way Transceiver and One 5-button Transmitter
* Parking Light Flash
* FailSafe® Starter Kill
* Clone-Safe® Code-Hopping
* Anti-Grind
* Built-in XCRS™ (Extreme Capacity Relay Satellite)
* Bright Blue LED Status Indicator
* Stinger® DoubleGuard® Shock Sensor
* Defroster Output
$375.00
Python 1601 Remote Start / Security System with Two 1-way SuperCode™ Remotes.
Features
* Keyless entry with optional progressive driver’s unlocking
* Silent Mode arming and disarming
* Revenger Soft Chirp Six-Tone Neo Siren
* Trunk Release plus 3 AUX outputs
* New, slim 5-button remote controls (two)
* XpressPort dock for Xpresskit docking serial date interface modules
* New Priority™ user interface with easy 2-car operation
* Warn-Away: low-volume, brief warning signal for questionable threats
* Flex Relays for remote start and light flash
* Control Center™ with integrated Status LED and Valet Switch
* Inputs for doors, hood, and trunk monitoring
* Manual Transmission Mode
* Virtual Tach™ RPM sensing
* Car Finder
* Progressive Door Trigger
* Advanced remote start functions: Timer Start, Smart Start, RunTime Reset
* Ports for optional tilt, glass break, cabin, and proximity sensors
* NPC patented Nuisance Prevention software
* D2D serial data interface for Xpresskit D2D serial data interface modules
* 2000' of range
WE DO IT ALL, FROM PAINT TO FIBERGLASS, FRAME SECTIONING TO LIFTS, CONVERSIONS TO VERTICAL DOORS..
http://www.XCLUZIVEAUTOWORKZ.COM
Old 09/15/2011, 11:43 AM   #2
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
Default Re: REMOTE STARTS!! and ALARM COMBOS
PYTHON CONTINUED
REMOTE START/KEYLESS ONLY UNITS
$325
Python 580 with 2-Way Responder LE SuperCode™ Remote.
Featuring 2000' range with SuperCode, Python's groundbreaking remote control is the slimmest 2-way remote available! Key features include:
* Remote can confirm commands with tones and Ghostlights
* Tone and Ghostlight visual notifications and confirmations
* Temp Check – displays internal cabin temp while remote start engaged
Features
* D2D serial data interface for Xpresskit D2D modules
* OEM Security Interface – alerts of any trigger to your OEM security system
* Onboard Flex Relays for remote start and light flash
* XpressPort dock for Xpresskit docking interface modules
* Car Finder
* New Priority™ 5-button user interface with easy 2-car operation
* Optional Anti-grind
* New, slim 5-button SuperCode 1-way companion remote control
* Advanced remote start functions: Timer Start, Smart Start, RunTime Reset, and more
* Keyless entry with optional progressive driver's unlocking
* Take-Over Mode
$225
Python 1401 Remote Start System with Two 1-way SuperCode™ Remotes.
Start your engine with the push of a button from up to 2,000 feet away with these slender, elegant 5 button remote controls. Based on the best-selling 2-Way Responder LE Remote Start System, this is the value-priced 1-Way version. Includes the very latest in Remote Start technology, including Virtual Tach, D2D and XPRESSPORT™.
Features
* Car Finder
* Take-Over Mode
* 2000' of range
$200
PYTHON 413 4103P
1-Way Remote Start System
The new entry level Python models offer unmatched value and performance that compliments the rest of the Python line of products.
Features
* Two 1-way 4 button remotes
* Superhet (HX+) receiver for superior range
* 4 channel outputs
* Outputs for optional horn and starter kill/anti-grind relays
* All Required Harnesses for Installation
* Virtual Tach™ eliminates the need for a tach wire in most installations
* New D2D serial port performance matched for Xpresskit interface modules
* Onboard XCR relays
* Bitwriter programmable for simple configuration
Old 09/15/2011, 11:56 AM   #3
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
PYTHON SMART START UNITS
$225
Directed SmartStart Module (DSM200)
If you already have a compatible Directed remote start system, you can add the DSM200 module to make your system SmartStart ready.
* WHAT'S REQUIRED
* Compatible iPhone, BlackBerry or Android smartphone (not included)
* This DSM200 Module
* A compatible Directed system in your car
* An activated SmartStart service plan. Choose from Secure 1-year or Secure 3-year plans starting as low as $3/month
* Certain functions not available on all systems. Professional installation required
* SmartStart currently works in the United States and Canada. For questions about operation in other countries, please contact the SmartStart team at smartstart@directed.com
* Compatible with any ESP2-enabled Directed system. Ask your installer if your existing Directed system is SmartStart-ready
$325
Ultimate add-on to a Directed security or remote start system.
Supported by v2.2+ apps on iPhone, Android, and selected BlackBerry smartphones.
The new DSM250 combines GPS tracking capability with current SmartStart 2.0 features. Know where your vehicle is at all times, keep track of and protect family vehicles, and enjoy a keyless connected lifestyle. Remote start or lock and unlock your vehicle and receive alerts on your smartphone if your vehicle is moved or driven where you don’t want it driven. You can even share your vehicle’s location with family or friends via mail, text, or your Facebook page.
Key Features:
* Sell as stand-alone product (w/tracking features only) or in full SmartStart system.
* Attractively priced Standard and Premium SmartStart+GPS service plans offered.
* Ultimate add-on to a Directed security or remote start system.
* Supported by v2.2+ apps on iPhone, Android, and selected BlackBerry smartphones.
$525
Python SmartStart Complete Security and Remote Start System
Includes SmartStart 2.0 module and harness, one 4-button remote and IVU supplied. Supports security alerts via SmartStart app.
* KEY FEATURES
* Combines classic Python hybrid performance with SmartStart 2.0 capability at attractive retail price
* Adds 2-way functionality via SmartStart app, with security alerts and command confirmation
* Supplied with 474T 1-way 4-button remote
* Bitwriter programmable w/o remote present, for easy system configuration
* Interface module must be hard-wired (D2D port used for SmartStart data connection)
* Lock, Unlock, Trunk Release, and Remote Start
* Fault proof starter interrupt, Nuisance prevention, Warn away, Limited Lifetime Warranty
* Includes:
* Classic Main Module
* Directed SmartStart 2.0 module
* Quick reference guides
ALARM/KEYLESS ONLY UNITS
$275
PYTHON Responder 460 3305P
Python® is proud to introduce our most affordable 2-Way security system which will wrap your vehicle in protection, with the most sophisticated electronic technologies available today, including the Stinger® DoubleGuard® shock sensor, Revenger® six-tone siren and Failsafe® Starter Kill. This state-of-the-art system also offers in-demand convenience feature like keyless entry.
Features
* 3 Channel Security/Keyless Entry System
* Clone-Safe® Code-Hopping®
* Failsafe® Starter Kill - On-board Relay
* 2 Auxiliary Outputs
* Includes one 2-Way and one 1-Way remote
* Revenger® Six-tone Siren
* On-board Stinger® DoubleGuard® Shock Sensor
$225
PYTHON 460 Max 3105P
Security System
Now featuring 4-button remotes, Control Center and XR+ receiver, this Python security system will wrap your vehicle in protection, with the most sophisticated electronic technologies available today, including the Stinger® DoubleGuard® shock sensor, Revenger® six-tone siren and Failsafe® Starter Kill. This state-of-the-art system also offers in-demand convenience feature like keyless entry. Please refer to the technology section for more information about security technologies used in this security system.
Features
* Control Center with antenna, Valet switch and Status LED combined in one unit
* XR+ super-heterodyne receiver for range up to one quarter mile
* Includes Two 4-button Transmitters
Old 09/15/2011, 12:11 PM   #4
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
edited..... no scytek stuff
Old 09/16/2011, 11:00 AM   #5
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
WILL BE ADDING MORE UNITS THIS WEEKEND
Old 09/16/2011, 06:41 PM   #6
BR8KNNX
BR8KNNX is offline
I got 5000rs installed on my accord and its good quality!
Old 09/17/2011, 11:51 AM   #7
EGTypeR
EGTypeR's Avatar
EGTypeR is offline
can you guys upgrade my 350hv viper and make it a 2-way?
Old 09/17/2011, 12:27 PM   #8
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
yes we can do it, but unless you have atleast the 2 way remote already it would almost be cheaper to buy a 2 way system.
Old 09/18/2011, 02:39 AM   #9
Bryce
Bryce's Avatar
Bryce is offline
Is there just and alarm on I don't have power locks so I don't think you could hook up a locking one Damn 80s vehicles
Originally Posted by Tripz_12 View Post
i was just asking haha i tought they were bfffs (best fucking friends for ever)
Old 09/18/2011, 03:15 PM   #10
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
Yea i have alarms kits only.. Ill get posted up tomorrow.. We can install power locks though if u want em
Old 09/19/2011, 12:22 AM   #11
Bryce
Bryce's Avatar
Bryce is offline
I imagine that's a pretty penny tho but ill have to look into it I've put to much work into my truck for it to be broke into I'll get ahold of you to let you know what's going on
Old 09/19/2011, 11:13 AM   #12
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
power lock kits really aint to bad as far as pricing.. ill shoot ya a pm
Old 09/27/2011, 02:45 PM   #13
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
just added one more smart start system to the list.. PS5000 all in one gps unit
Old 09/29/2011, 10:36 AM   #14
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
JUST ADDED ALARM ONLY UNITS ABOVE.. CHECK IT OUT.. PRICES LISTED ARE ALL INCLUDING INSTALL.. additional things like relays and modules are extra
Old 10/24/2011, 05:29 PM   #15
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
As of now we are no longer offering scytek products.. everything is all Directed products (python,viper,avital etc.)
Old 02/23/2012, 05:27 PM   #16
XCLUZIVEAUTOWRKZ
"GANGMEMBER"
Bump.
Old 03/10/2013, 06:41 PM   #17
Penten
Penten's Avatar
Penten is offline
If I bring the kit will you guys install it and at what rate if you do?
