Old 10/25/2011, 09:05 AM   #1
JBAutosports
JBAutosports's Avatar
JBAutosports is offline
Default ZOMBIES!!!! - Some amazing deals before these bastards get our brains!
JB Autosports is having a limited time sale from now until Halloween ends Monday the 31st @ midnight!
Limited quantities so act fast! Please enter your make and model on our site to check for items you may want a special deal on.
PM FOR SPECIAL PRICING!
ACT Clutch Kit - Street Disc Heavy Duty
aFe Intake System
Replace the entire air box and intake tract with the aFe Stage 2 Open Element Air Intake System.
AEM Evo X Air Induction System
Designed to produce massive horsepower and torque gains as well as better engine sound when used as a replacement for the factory airbox and air filter.
This system is completely street Legal in all US States (CARB EO Number: D-670) Dyno tests have proven estimated Horsepower Gains upto 17 HP @ 4100 RPM. Hands down, this is one of the best intakes on market for your Evo X, no doubt!!!
AEM Guages
UEGO, TRU-BOOST and more!
Brian Crower Cams
BC high performance camshafts are ground on state-of-the-art CNC cam grinders to insure accuracy and tolerances to within .02mm. Every BC camshaft profile has been prototyped and dyno tested for proven horsepower results prior to placed into mass production. By grinding cores in high volume, Brian Crower, Inc. is able to pass the cost savings on to the end user. Quality at an affordable price.
Cobb AccessPORT
-Incredible power gains are just a few clicks and a flash away.
-Sophisticated logic of the OEM ECU remains intact, providing refined response, excellent driveability and precise control.
-Hand-held flashing lets you control what is stored on the ECU, when-ever and where-ever you want.
-Installs in just minutes through the OBD-II connector. No tools or other actions are necessary. Simply flash and drive.
-Grows with your modifications by changing maps that match your mods.
-Select from Off-The-Shelf maps to match your modifications, self-tune with AccessTUNER
-Uninstalls just as easily and returns ECU to stock configuration.
-Conveniently data log sensor values for up to 10 hours to perform in-depth analysis without the need for bulky laptops or other equipment
-Vibrant-color, user-configurable auxillary gauge. Live Data lets you view real-time data from any of the data channels that can be data logged.
-Performane tools record 0-60mph times and 1/4 mile ET and Trap Speed. See real world impact of modifications and tuning changes.
-Intuitive DTC code reading provides the trouble code and a brief description to help diagnose issues easily. Reset the ECU to clear codes at your convenience.
-30 Day Satisfaction Guarantee.
Greddy Comp Ti-C Turbo back with downpipe!
For full on competition use only, we now offer the “turbo-back” Comp Ti-C series. These are full race turbo applications which include a large racing dowpipe to replace the factory catalytic converters at the race track. The Comp Ti-C is for off-road use only.
GSC Power Division Camshafts
Power Division High Performance Billet Camshafts. Engineered to offer the absolute best performance and maintain close to stock drivability characteristics. Power Division has stepped into the market with top quality Billet Cores that will perform with or outperform other camshafts on the market. With the wide array of profiles there is a combination to fit your needs. From basic bolt-ons to fully built engines naturally aspired or Turbo Charged. Power Division offers the setup to suit your needs. All the camshafts provide power across the RPM band and can support extreme race engine conditions due to their superb quality. Why run the others, when you can run the BEST!
GTSPEC
Ladder Brace
The GTSPEC Ladder Brace is a four point undercarriage brace reinforcing the connection between the control arms and chassis. Engineered and manufactured from 6061 aircraft grade aluminum for lightweight construction and increased structural rigidity, it is a direct bolt on.
Injen Intake
Polished or Black
The Injen SP Series Intake Systems Feature the Patent Pending MR Technology Process for Optimal Gains and a Safe A/F Ratio. The Injen SP Series Intake System does not limit itself to just a Cold Air System or Short Ram System. The MR Technology process has its effects on both types. The Injen SP Series Intake is The World’s First Tuned Intake System
Invidia
Single exit cat back with TI Tip.
Keep the weight down without the addition of the larger muffler and dual exit. Good quality for an unbelievable price!
Invidia
Dual exit with TI Tips. Keep that stock dual tip look but increase flow and add an aggressive sound.
Maganaflow
3" Piping with 4" dual tip muffler!
Mishimoto
Mishimoto has just released the new X-Line of high performance aluminum radiators. Each new X-Line radiator application has 3 rows for a core that is 25% larger than standard radiator applications. The triple core design of the X-Line radiator allows more coolant to flow through, maximizing engine cooling capacity. Each application is designed as a direct OEM replacement, with no customization required for installation.
SPEC Stage 3+
The SPEC Stage 3 Clutch Kit PLUS is the flagship stage for a high powered street or race car that requires a manageable and friendly engagement, the stage 3+ features a carbon semi-metallic full faced material that offers unparalleled life, friction co-efficient and drivability characteristics in one single package. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Great for street, drag, drift, autocross, road racing, pulling, rallye and drift.
TurboXS FMIC Kit
We use 19x11.5x3 core with the proper fin density to ensure the best heat dissipation throughout the bar and plate core, while keeping pressure drop to a minimal. The use of a core this size is good for up to 800 hp! On each side of the core we use a 2.5 inch inlet and outlet allow this core to be used as a core only upgrade. Which bolts into the place of your stock intercooler seamlessly.
Feel free to PM us on anything else!
Phone:
888-885-2002
SPECIAL PRICING VIA PM
www.jbautosports.com
