Old 12/14/2011, 08:33 PM   #1
JBAutosports
JBAutosports's Avatar
JBAutosports is offline
Default Coilover Systems - Fortune Auto / Eibach / KW / Stance / KSport / HKS / Function Form
Tons of good coilover options available for most cars. Give us a PM and we can help pick out the right coilover for you, along with offering very competitive pricing. Check our website out for all options, and PM us for the special JDMCITY price. Make sure to select your car model on our website to narrow down your choices.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Function and Form
One year warranty. 32 levels of dampening adjustments. Dampening adjustments made with a knob that “clicks at each level. Steel construction of lower mounts for maximum strength. Adjustable pillow ball mounts. Adjustable ride height from the bottom mount. [1] Special oil lubrication to withstand conditions from -40 degrees C to 200 degrees C [2] Dual tube shock design for maximum ride comfort. Double wishbone piston size 43mm. *Depending on applications. [1] This allows the user to retain full shock travel, while being able to lower the car significantly. [2] Allowing the shock to perform in even the most demanding environments.
Type 1 and Type 2
Fortune Auto
These are a great option for the budget minded racer. They are rebuild-able right here in the USA and all options offer custom spring rates and valving.
Click the images to learn more:
500 Series
510 Series
DREADNOUGHT© Inverted Coilovers
Eibach Coilovers
These state-of-the-art, race-ready, damping-adjustable coil-overs use a monotube damper design for maximum track performance. Ride height is infinitely adjustable between 0.80” – 2.5” lower than stock, and the dual-spring setup is dialed for maximum cornering performance. Rebound and compression damping are both adjusted-ensuring proper damping balance at any setting.
Multi Pro R1
Multi Pro R2
HKS Coilovers
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS’ all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
Hipermax III
KSport Coilovers
Ksport Version RR Damper System is built specifically for road racing only. Aggressive rates and valving are chosen for maximum handling and performance with acute reaction and responsiveness. Integrated with 36 levels of dampening adjustment, simultaneous compression and rebound adjustment, lightweight aluminum mounts, and pillow ball upper mounts on some applications.
KW Variant 3 Coilovers
KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
Stance Coilovers
Stnace GR+Pro [SS-D] The Special Setting Dampers were developed to meet the special demands of the circuit. The SS-D is valved to work in conjunction with race tires to maximize traction. The GR+ Pro SS-D were used to win national titles in both drifting and time attack; setting the highest benchmark for itself – winning.
Stance GR+ Pro SS-D
Don't see something listed? PM me!
Phone:
888-885-2002
SPECIAL PRICING VIA PM
www.jbautosports.com
Old 12/15/2011, 07:43 PM   #2
Default Re: Coilover Systems - Fortune Auto / Eibach / KW / Stance / KSport / HKS / Function
I have those Stance coilovers, and all I have to say is. Anyone thinking about getting them, buy them. The best suspension I have come across so far. Absolutely amazing!
Old 12/16/2011, 11:20 PM   #3
luis31
Jefe De Jefes
luis31's Avatar
luis31 is offline
Can you pm me pricing on kw variants for 06 civic si. (If they make em)
Also. Ksports. Thanks.
Old 12/17/2011, 01:51 PM   #4
JBAutosports
You got a PM boss. :)
All KW's have a wicked price right now!
Phone:
888-885-2002
Old 12/19/2011, 10:51 AM   #5
JBAutosports
Couple more to add to the list. :)
Moton
AST
Cusco
Tein
Phone:
888-885-2002
Old 12/19/2011, 02:28 PM   #6
blacksheep
blacksheep's Avatar
blacksheep is offline
Old 12/20/2011, 01:40 PM   #7
jdmb18hatch
Retired
jdmb18hatch's Avatar
jdmb18hatch is offline
^^^hahaha
Old 12/27/2011, 05:03 PM   #8
JBAutosports
FAP
Phone:
888-885-2002
Old 01/27/2012, 08:05 PM   #9
JBAutosports
Rocking all sorts of good deals still guys!
Phone:
888-885-2002
Old 03/08/2012, 07:03 AM   #10
JBAutosports
Tons of great deals here for coilovers. Fortune Autos are at a 3 week lead time right now so get your order in for one of the most affordable USA supported coilovers on the market.
Fortune Auto
These are a great option for the budget minded racer. They are rebuild-able right here in the USA and all options offer custom spring rates and valving. Track Tested!
Each set is built to order. You pick the spring rate, you pick the valving, and you pick the upgrades. Totally custom for your specific need.
Swift Spring Upgarde - Available
Roller Bearing Upgrade - Available
Rear Helper Spring Upgrade - Available
Custom Colors - Available
500 Series Available - MSRP $1099
510 Series Available - MSRP $1499
Phone:
888-885-2002
Old 03/12/2012, 08:04 AM   #11
blacksheep
blacksheep's Avatar
Car show/Auto-x/HPDE/Track days are all coming up soon, people. Time to get your ride ready...
Old 03/18/2012, 06:02 PM   #12
JBAutosports
Still smashing out deals on all brands of coilovers.
Phone:
888-885-2002
Old 04/07/2012, 10:55 PM   #13
blacksheep
blacksheep's Avatar
Get ready for the 22nd April car show with some coilovers!
Old 05/21/2012, 03:34 PM   #14
JBAutosports
bump!
Phone:
888-885-2002
Old 05/21/2012, 11:02 PM   #15
Pancho
Pancho's Avatar
Pancho is offline
Pm'd
92 Civic Hatch SI [Sold]
92 Talon Tsi AWD[Sold]
93 Civic Hatch SI [Sold]
Old 05/22/2012, 10:57 AM   #16
JBAutosports
PM replied
Phone:
888-885-2002
Old 07/30/2012, 09:56 AM   #17
JBAutosports
Up top. Coils galore hit us up. We carry 90% of Coilover brands.
Phone:
888-885-2002
