Old 12/22/2011, 10:22 AM   #1
JBAutosports
JBAutosports's Avatar
JBAutosports is offline
Default Radiator Upgrade Kits! - Koyo / BWR / Agency Power / Samco / Mishimoto / Megan
Radiator and hose kits available to keep your car cool on or off the track. Tons of mix and match combos available for any budget. Select a radiator, a hose kit, and fans if you need and then PM us for the special JDMCITY Forums price. If you use our website please remember to select your car when searching for items that will fit your vehicle.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Agency Power
The all aluminum radiator features a high pressure radiator cap, aluminum construction, and mounting tabs for a direct OEM replacement. The factory fans and radiator hoses will fit with no modification. This kit is very easy to install and should only take about 1 hour. In addition to having a larger cooling capacity, the aluminum radiators are much more durable then stock. The factory plastic end tanks can crack under extreme heat and pressure. Under racing conditions, your water temperatures can near boiling points. As tested under the intense Arizona heat conditions, the aluminum end tanks and larger core size help keep the temperature down by at least 15F degrees
Agency Power Aluminum Radiator Kit
Koyo
Built with a robust 53mm core, the R-Core Series is engineered for the serious performance tuner. Increased capacity means better cooling reserve when you need it. Intended for both circuit and daily use, you may double your coolant capacity and see up to 35% increased performance over your stock radiator.
All Koyorad R-Series All Aluminum Radiators are Nocolok brazed, designed as a factory fit, direct bolt in with no engine modifications necessary, and retain mounts for the stock fan shrouds and fans.
Koyo Radiator - R-Series
BlackWorks Racing
If your in the market for a high flowing, high performance radiator BlackWorks Racing is your best bet. Do not be fooled by other imitation companies. BlackWorks Racing stands behind our products with a life time warranty against manufacture defects.
BlackWorks Racing is a great upgrade for your street car, weekend warrior, or full on track car. With our dual core design, cooling your vehicle is not a problem. The BlackWorks Racing radiators will keep your engine cool even under the most extreme high heat racing conditions, or driving in the high heat hellish temperatures in the desert of Arizona.
So rest assured, your investment with a BlackWorks Racing radiator will not only be the best purchase but will be the last. BlackWorks Racing Radiators are a direct replacement with being able to use all stock fans and hoses if desired.
BWR Aluminum Radiator
Mishimoto
Whether you are a daily driver looking for an upgrade to your OEM radiator, or a racer looking for a dependable quality radiator, we have just what you are looking for! Mishimoto Performance Radiators are 100% brazed aluminum, ensuring a lasting lifetime of efficient cooling.
Megan Racing
Anytime an individual introduces their car to a racing/drifting environment, the temperature of the vehicles engine will skyrocket. One common and effective method of reducing engine temperature is to employ an aluminum radiator. This is a cost effective upgrade which can ultimately save an engine during competition or spirited driving. Often times, a temperature drop of twenty degrees or more will be noticed when using an aluminum radiator. Also included is a 1.1 BAR radiator cap.
Megan Racing Radiator
Agency Power Hoses
The amount of heat a performance motor puts out is far greater then most standard designed engines. For high performance needs, keeping a cars engine temperatures down and efficient is EXTREMELY important. Agency Power now offers this 5 ply silicone radiator hose kit for your Vehicle. These hoses replace your factory hoses. The OEM rubber hose tends to burst under extreme heat and crack over time. These silicone hoses improve flow and are not affected by heat like rubber hoses. They come in 3 powerful colors. Glossy black, red, or blue are available. Each hose kit includes new clamps for easy installation.
Blue and Red Available.
BlackWorks Racing
When upgrading your engines performance and horsepower, it is essential to upgrade your cooling system as well. The BWR Radiator Hose Kits are hand crafted to ensure the highest quality. With the newly designed multi ply (one of the only 4-ply kits on the market) design these hoses will handle the high temperatures and higher pressures produced by high performance Honda/ Acura engines.
BWR’s kit is ideal for both your full on race car or your daily driven street grocery getter. Along with all of the performance and reliability benefits you will gain, this hose kit will also give your engine bay a clean and amazing look.
Most kits are available in Black,Blue, and Red.
Blue, Red, and Black Available.
Mishimoto Radiator Hose Kit
Mishimoto Radiator Hose Kits are made with a dual layer combining high grade silicone and Dupont Nomex technology to provide efficient heat reduction and increased pressure tolerance.
Specifications
Interior Color: Orange
Interior Material: Nomex
Exterior Color: Black/Blue/Orange/Red
Exterior Material: Silicone
Max Temperature: 330 F
Blue, Red, Black, and Orange Available.
Samco Hose Kit
The Samco Sport Radiator Hose Kits provide a unique opportunity to upgrade your intercooler hoses to a product that is simply un-rivalled worldwide for performance and looks. These direct replacement silicone hoses are available in 7 striking colors to blend with your engine the way YOU want. Whatever color you choose just remember, you’re fitting the finest radiator hoses that are designed to perform under pressure.
Red and Black in stock. Can Special order White, Pink, Yellow, Green, Urban Camo, and more
Mishimoto Slim Fans
The Mishimoto Radiator Fan can be used as an upgrade to the OEM fan for more efficient cooling or fitment issues with aftermarket products. With the Mishimoto Radiator Fan’s slim design, the fan can easily be installed flush against a radiator.
For universal installation, use Mishimoto universal fan mount kit. (P/N: MMFAN-Mount)
Available in 10”, 12” and 14” Applications.
Pick a size and qty. :)
Phone:
888-885-2002
SPECIAL PRICING VIA PM
www.jbautosports.com
Old 12/22/2011, 01:56 PM   #2
Default Re: Radiator Upgrade Kits! - Koyo / BWR / Agency Power / Samco / Mishimoto / Megan
AWESOME SUPER GREAT DEALS......So good I had to take advantage of them!!!
Old 12/22/2011, 03:11 PM   #3
JBAutosports
Thank you for the order! :)
Phone:
888-885-2002
