#1 |
![]() Join Date: Jun 2011
Just an example of what we have and do for the S2000 in this area, and it's just a tiny portion. We can hook up just about any make and model with similar items. :)
This is what we do and we are local. Hit us up for anything you need. We match pricing if not beat them! ![]() We have coilovers from all of the popular brands like Fortune Auto, KSport, BC Racing, KW, AST, H&R, Eibach, and more. We also have some great deals on rotors from DBA and Power Slot along with pads from HAWK and brake lines from Goodridge and Techna-Fit. Custom packages available and we will fit you with the right parts for your budget and type of autosports activites whether it be street, track, drift, or autocross. Lets start off with Coilovers! Tons of good coilover options. Give us a PM and we can help pick out the right coilover for you, along with offering very competitive pricing. Check our website out for all options, and PM us for the special JDMCity price. Fortune Auto These are a great option for the budget minded racer. They are rebuild-able right here in the USA and all options offer custom spring rates and valving. Track Tested! Each set is built to order. You pick the spring rate, you pick the valving, and you pick the upgrades. Totally custom for your specific need. Swift Spring Upgarde - Available Roller Bearing Upgrade - Available Rear Helper Spring Upgrade - Available Custom Colors - Available 500 Series Available - MSRP $1099 ![]() 510 Series Available - MSRP $1499 ![]() KSport Another great coilover line. Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. KSport Kontrol Pro ![]() KW ![]() Don't need the wallet pain the coilovers bring? No problem get yourself some nice springs instead. Eibach ![]() H&R ![]() Lets not forget about that front sway bar or brace offered by Whiteline ![]() Megan Racing Drive Shaft Spacers The driveshaft of the Honda S2000 is designed at a stock height. Megan Racing have created these spacers to bring back the stock length causing the driveshaft to reached the stock length when the car is lowered. ![]() Eibach Sway Bars ![]() Alginment Kits from SPC ![]() It's time for some rotor love. Make sure you have what it takes to get the S2000 stopped on the track or street. These rotors add not only the power to stop but they also add an aggressive look. DBA Rotors DBA rotors are a enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. Suitable for specific production car motorsport use. Available in single(4000 series) or two piece rotors (5000 series). ![]() XS Series The unique ‘XS’ pattern is a premium (advanced) cross-drilled and slotted pattern, providing improved braking performance for street use only. Available in single(4000 series) or two piece rotors (5000 series). ![]() POWERSLOT Excessive heat can cause resins in your brake pad to vaporize or “outgas.” As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here’s where Power Slot’s slotted brake rotors make a big difference. ![]() Ready to go big time with a big brake kit? KSport Big Brake Kit Ksport Big Brake Kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications). ![]() And to go with those nice new DBA rotors how about some HAWK Brake pads. Everything from street use with the HPS, to light track with the HP+ or HP Blue all the way up to the DTC compounds for the serious track warriors. HAWK Hawk Performance’s leading-edge brake friction technology is proven everyday in severe-duty aerospace, military, commercial truck fleet, motorsports and performance street brake applications. Put the power in the brake pedal and specify Hawk Performance disc brake pads. ![]() To handle even more heat and pressure check out Goodridge or Techna-Fit stainless lines, and don't forget Motul DOT 5.1 fluid. ![]() __________________ E-Mail: sales@jbautosports.com (best way to contact) Phone: 888-885-2002 SPECIAL PRICING VIA PM www.jbautosports.com AUTHORIZED DEALER FOR OVER 400 PRODUCT LINES Like us on Facebook for Facebook only specials! ![]() |
#2 |
![]() Join Date: Mar 2009
Do you guys not offer H&R race springs for the s2000?
#3 |
They only make Sport Springs for the S2000.
#4 |
![]() Join Date: Feb 2007
Only recommended race springs are the Eibach pro-kit or The Swift Spec-R's. We have the eibach in stock for local pick-up, Tommy. Jump on these!
![]() __________________ 1992 Mitsubishi Galant VR-4 #205/1000 |
#5 |
Gotta figure out what's up with my suspension first, then I will!
#6 |
What issue(s) are you having? Let me know and I can help troubleshoot...
#7 |
All makes all models. PM me!
#8 |
Check us out at
http://jbautosports.com AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES ![]() Like us on Facebook for Facebook only specials! ![]() __________________ E-Mail: sales@jbautosports.com (best way to contact) Phone: 888-885-2002 SPECIAL PRICING VIA PM www.jbautosports.com AUTHORIZED DEALER FOR OVER 400 PRODUCT LINES Like us on Facebook for Facebook only specials! ![]() |
#9 |
Get your S2000 hooked up with us!
Thread Tools | |
