Old 04/10/2012, 09:51 AM   #1
civytrent1
civytrent1's Avatar
civytrent1 is offline
Default ideas for my 90 accord
so i just picked it up a few days ago and trying to figure out what i wanna do with it. any ideas? it is a five speed
87 saab 900 spg turbo(only kinda stock)
87 Alfa Romeo 75t aka Italian fun toy
93 subaru legacy wagon (rally car)
Old 04/10/2012, 11:24 PM   #2
H22CB9
H22CB9's Avatar
H22CB9 is offline
Default Re: ideas for my 90 accord
H22A swap
Old 04/11/2012, 12:26 AM   #3
93CB7Tuner
93CB7Tuner's Avatar
93CB7Tuner is offline
Lower it.
Old 04/11/2012, 08:19 PM   #4
civytrent1
civytrent1's Avatar
i'm lowering it on friday. i'm trying to figure out what i want to do with the exhaust and body. there is no rust. got it from missouri
Old 04/12/2012, 01:20 PM   #5
4DRLX
4DRLX's Avatar
4DRLX is offline
heres my number call or text me if u need anything or got any questions.
my names david 515-669-8025
edit: their is many things you can do with it. not knowing your history with hondas or f/h series motors heres my 2 cents.
it all depends on your budget.
1. H22 swap
you could go with the typical h22 swap, h series and f series motors and transmissions are all interchangable. though if you swapped an h22 you would not get the full potential of the engine with an f22 tranny or h23 tranny. but if moneys tight and u find a good deal ona motor then its an option.
2. F22 Turbo
The stock f22 is a decently strong motor when mated with good head studs and a quality head gasket. alot of guys then run a DSM turbo setup on it with low boost 6-8psi this would put you up around a stock h22 swap and potentially a cheaper solution, not guaranteeing the logetivity of the motor though (good a good tuner)
3. BE DIFFERENT H23 Vtec swap
4. H23 turbo
swap an h23 in and boost it. f series exhaust manifold and h23 manifolds are the same pattern. H22 is NOT.
for further info go here: www.cb7tuner.com
Old 04/12/2012, 01:53 PM   #6
4DRLX
4DRLX's Avatar
4DRLX is offline
simple bolt on mods you can do to your stock f22.
intake pipe/ filter
h23 intake manifold (bolts right up) plus i have one if you want to buy it
depending on what motor you have... say you have the f22a1 i believe the f22a6 exhaust manifold is free'r flowing.
Old 04/12/2012, 10:21 PM   #7
benstuh
benstuh's Avatar
benstuh is offline
intake pipe/ filter
f22a4
Old 04/13/2012, 10:11 AM   #8
civytrent1
civytrent1's Avatar
i thought about building up my f22. my buddies brother did a f22 vtec head swap on his then turbo'd it and its pretty quick.
where is a good place to do rust work for a pretty good price my rear wheel wells need attention.
i need to get a front passenger fender too.
just stock i like this car. i would take it over my old da or my ef any day of the week now.
Old 04/13/2012, 11:05 AM   #9
mr.carr
drift_kid_s13
mr.carr's Avatar
mr.carr is offline
no offence but the vtec heads sucks. the flow is horrible, they suffocate the motor more than it helps. the ports suck the exhaust ports makes hot spots. tuning with those heads are just a headache. so that head swap is useless even if you build it.
five things to make power or to unlock power.
1st: cut the f22 head and go with a h22
2nd: find a dsm turbo and mani
3rd: delete the balancer
4th: delete the egr
and
5th: find a obd1 pr4, p75, or p28 and chip it.
Google Monster
Originally Posted by Rob Dahm
Old 04/13/2012, 11:35 AM   #10
civytrent1
civytrent1's Avatar
i have 2 turbos from my alfa and saab. plus my intercooler set up from when i was building my ef. how much does a h22 run? plus id have to get a h series tranny for better power? thats what i heard.
Old 04/13/2012, 12:46 PM   #11
benstuh
benstuh's Avatar
benstuh is offline
4th: delete the egr
and
"G22" isn't worth it either, they are difficult to tune, unless you have a really really good tuner to tune your car.
Old 04/15/2012, 01:43 AM   #12
4DRLX
4DRLX's Avatar
4DRLX is offline
Default
No need to put a h22 head on to boost... just mildly build the f22 head, arp studs and new hg. Throw 14psi at it. Take it to central imports for a tune.
Im planning a long f22 build as we speak. And then the h22 will be going in a db7.
Old 04/15/2012, 01:11 PM   #13
civytrent1
civytrent1's Avatar
yeah i was told just build the f series and boost it. i got new headstuds and hg. im thinking about redoing all the bearings and rings too. what you think about doing that?
Old 04/15/2012, 02:09 PM   #14
benstuh
benstuh's Avatar
benstuh is offline
as long as you use quality parts and not shitty ones for bearings and rings. gaskets etc. then you should be fine.
Old 04/15/2012, 02:40 PM   #15
civytrent1
civytrent1's Avatar
im not going cheap for it. i want to make it worth my time
Old 04/15/2012, 05:44 PM   #16
Cyberwaste
LURKIN
Cyberwaste's Avatar
Cyberwaste is offline
take pictures of it an alley and by construction sites.
http://imgur.com/N3ABL
Old 04/15/2012, 09:55 PM   #17
4DRLX
4DRLX's Avatar
4DRLX is offline
Default
I cant stress this enough..
Go on cb7tuner.com
Search 90turboaccord's member ride thread... be amazed at f22 power.
Old 04/15/2012, 09:59 PM   #18
civytrent1
civytrent1's Avatar
Go on cb7tuner.com
alright i shall do that. i have been looking up alot on them and. its not a bad motor for a good build. just gotta fix dents now thanks to the damn storms yesterday
Old 04/15/2012, 11:26 PM   #19
benstuh
benstuh's Avatar
benstuh is offline
I have a spare block from my old f22a6 if you need a spare motor to build while driving lol
Old 04/16/2012, 12:08 AM   #20
93CB7Tuner
93CB7Tuner's Avatar
K-Series.
Old 04/16/2012, 01:23 AM   #21
civytrent1
civytrent1's Avatar
i may end up needing to get your block from you some time.
and k series? ever cb7 ive read up on has either the f series or h series.. plus that a pretty good chunk of money for that isnt it?
Old 04/16/2012, 08:50 AM   #22
benstuh
benstuh's Avatar
benstuh is offline
K series has been done before, its just h series is a direct drop in , that's why most people go that route.
Old 04/16/2012, 03:08 PM   #23
93CB7Tuner
93CB7Tuner's Avatar
There's about 5 K series CB7's
Old 04/18/2012, 11:28 PM   #24
JDMxTAi
JDMxTAi's Avatar
JDMxTAi is offline
Put some hydraulics on it. LMFAO
I've never seen a Honda With Hydraulics.
1996 Honda Civic EX Coupe - Blown & Sold
2011 Nissan Rogue SV AWD - DD
Old 04/19/2012, 09:49 AM   #25
4DRLX
4DRLX's Avatar
4DRLX is offline
NO lol
here this shall curb your need for such an illness...
