Old 10/12/2012, 02:43 PM   #1
bean_bean
bean_bean's Avatar
bean_bean is offline
Default need help or im getting killed so help me plzzzz
Ok was changing the radio out of the 92 accord and something went wrong I cut the wires and spliced them and hooked up the radio and it won't turn on and now the seatbelts won't retracked when the door is open like they should I replaced all the fues and it still won't work any ideas
turbo bitches!!!!!!!!!!!!
Old 10/12/2012, 02:58 PM   #2
4DRLX
4DRLX's Avatar
4DRLX is offline
Default
Wiring diagram and patience.
Old 10/12/2012, 03:04 PM   #3
Default Re: need help or im getting killed so help me plzzzz
First off, why did you cut the wires? 2nd its more then likely a fuse I can almost guarantee it. Check your cigarette lighter, if that isn't working either then you know. What I'm guessing happened is you shorted your power wire, it's possible you might have even wired in the power wire wrong as well and this is continuously causing you to blow a fuse every time you replace it, the second you turn the key it blows.
Now if that's not the case then you cut some other wire that is very important.
Old 10/12/2012, 03:05 PM   #4
bean_bean
bean_bean's Avatar
I pulled the wiring harness off the internet and I have all the wireing right but now the seatbelts won't move and I replaced the fues
Old 10/12/2012, 03:09 PM   #5
bean_bean
bean_bean's Avatar
I also made sure I only cut the wires that went to the radio nothing else
Old 10/12/2012, 03:11 PM   #6
Unplug your radio from the wiring, double check all of your fuses and then with the radio un plugged see if all your other stuff works fine. If it does then that'll help you narrow down where your problem is. If that doesn't take care of anything then you know it's not related to your radio.
Old 10/26/2012, 06:34 PM   #7
bean_bean
bean_bean's Avatar
ok well radio is in and works but for some reason the volume wont work on it i have to go throw all the levels and have to find one volume level for it to actully play and whenever i hit the bass or adjust button it cuts out and stops playing or play even louder then before and just blow my speakers pretty much lol
