Old 10/24/2012, 08:57 PM   #1
ThatGuyVanny
ThatGuyVanny's Avatar
ThatGuyVanny is offline
Default HELLPPPPP
MY heat stop working i have no idea why.....
Old 10/24/2012, 10:54 PM   #2
luis31
Jefe De Jefes
luis31's Avatar
luis31 is offline
Default Re: HELLPPPPP
Just the heat? How about the fan, does it blow air?
Old 10/25/2012, 08:45 AM   #3
ej1_dohc_vtec
ej1_dohc_vtec's Avatar
ej1_dohc_vtec is offline
Check fuses
Old 10/25/2012, 01:00 PM   #4
ThatGuyVanny
the fan blows fine..
Old 10/25/2012, 01:00 PM   #5
ThatGuyVanny
Originally Posted by ej1_dohc_vtec View Post
Check fuses
i will bro
Old 10/25/2012, 01:42 PM   #6
Em1LuiSiR
AWFD
Em1LuiSiR's Avatar
Em1LuiSiR is offline
thermstat maybe? do you start it and it never heats up but only blows air?
Old 10/25/2012, 02:31 PM   #7
I had the cable that runs from my climate control to the coolant valve break once. Could be that, idk where it's located on your car but on most cars its mounted on the firewall. I would presume its in the same spot if not close.
Old 10/25/2012, 02:33 PM   #8
Not entirely sure what it's like on the Accords. I would imagine it looks relatively close if not the same as this. It's also possible that the cable simply slipped off the arm that opens the valve.
Old 10/25/2012, 04:02 PM   #9
ThatGuyVanny
imma go check that soon thank:)
Old 10/25/2012, 04:03 PM   #10
ThatGuyVanny
i had let it sit there and wait till the heat comes on but no... it just blow air..
Old 10/25/2012, 04:56 PM   #11
If it's not anything listed then it could be a clogged heater core. You can test that before you go about ripping your dash out.
Drain your coolant and undo the feed and return hoses that go to the heater core, then plug a hose into one end and turn it on. If water doesn't come out then you know its a bad heater core. (make sure the valve is open it has to be open all the way when you do this)
Old 10/25/2012, 05:42 PM   #12
luis31
Jefe De Jefes
luis31's Avatar
luis31 is offline
Replace thermostat next, thats pretty common thing to go bad
Old 10/25/2012, 10:37 PM   #13
ThatGuyVanny
Alright thanks guys
