Old 05/27/2013, 05:19 PM   #1
JDM_Carson
JDM_Carson's Avatar
JDM_Carson is offline
Default Exhaust Help
On my civic, i have a skunk 2 megapower exhaust but the fitting makes it so it slowly is melting the exhaust fitting spot on the bumper, where can i get like a 2 inch exhaust tip extension?
Old 05/28/2013, 07:07 PM   #2
Default Re: Exhaust Help
Bend your hangers around so that is does not rest directly on the bumper. Just a little fine tuning. Also, loosen the bolts at the connections, and get the unit situated where you want it, then with tension on it, tighten it back up. This will most likely require a helper.
