Old 06/26/2013, 05:49 PM   #1
whitsingleslamer
whitsingleslamer is offline
Default b18c1 question
After I hit vtec at 6 my car blows a smoke cloud out but I read if ur compression is within 10-15 apart ur fine mine is 1-4 200 and 2-3 190 so I don't think its my rings... it didn't start this until I put my skunk2 intake and 68mm on.... so if anyone can help me
1998 White civic ls swapped sold
1997 ford f150 current
1998 gsr integra current
Old 06/26/2013, 05:59 PM   #2
Default Re: b18c1 question
sounds like rings on there way out,
Old 06/26/2013, 06:17 PM   #3
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
ConHuevos! is offline
possibly running a bit rich.... thats just a shot in the dark of course. tune?
Sri Sri Ravi Shankar
Old 06/26/2013, 07:29 PM   #4
Vtec fluid good?
Old 06/26/2013, 07:57 PM   #5
dat192
Honey boo boo
dat192's Avatar
dat192 is offline
Sounds like rings or idk possible intake manifold gasket?
1 bitch 2 bitch
fat bitch skinny bitch
Old 06/26/2013, 09:37 PM   #6
whitsingleslamer
I was thinkn valve seals
Old 06/26/2013, 09:47 PM   #7
michaelx43
michaelx43's Avatar
michaelx43 is offline
Originally Posted by crxh22honda View Post
Vtec fluid good?
x2
Old 06/27/2013, 12:02 AM   #8
If it is a little puff of oil smoke, I would say valve seals. Other possible issue is it is a little loaded on fuel, since you went to a single runner manifold, and you could be seeing the difference in fueling when vtec engages, and when the secondary butterflies are supposed to open. But that would definitely be a different color puff than burning oil.
Old 06/27/2013, 02:32 PM   #9
^^ Listen to him, he's got your answer right here.
What color is the puff of smoke? Also did you say vtec isn't engaging until 6k???
Old 06/27/2013, 10:00 PM   #10
mr.carr
drift_kid_s13
mr.carr's Avatar
mr.carr is offline
its a Honda they all burn oil.
Google Monster
Originally Posted by Rob Dahm
Old 06/27/2013, 10:03 PM   #11
aint that the truth
Old 06/27/2013, 11:49 PM   #12
Man, I built a fresh engine, didn't burn a drop. Beat the piss out of it. Many, many, passes at the track. Proper maintenance will solve a lot of the oil burning issues.
Old 06/28/2013, 09:19 AM   #13
I doubt it's because of the IM.
Even if you had a vaccum leak you would of heard that air leak on intital startup.
- look over the vaccum lines to make sure theres not rips/tears
typcially white smoke means it's coolant, but if it's burning coolant it would be consistant, not just at WOT after vtec.
are you on stock ecu?
even with stock ecu, the car shouldn't lean out too bad even with the addition of the skunk2 IM.
CNC Werx
team4piston
Jordan Tuned
Rocket Motorsports
Modern Automotive Performance
Old 07/04/2013, 09:31 PM   #14
whitsingleslamer
Its on a p73 Itr ecu now someone it smells like fuel... but the exhaust smells like coolant...
Old 07/25/2013, 12:50 PM   #15
H22CB9
H22CB9's Avatar
H22CB9 is offline
I say tune it cause you are allowing more air than fuel into the motor
