Old 08/25/2013, 02:00 AM   #1
dat192
Honey boo boo
dat192's Avatar
dat192 is offline
Default Odd problem
Recently swapped my car and Now has 350 miles on everything. I bought new axles and all that good stuff. Bought a new clutch also. And now I'm first gear it feels as tho something isnt making what feels like a straight rotation if that makes sense. Any suggestions? Just comment.
1 bitch 2 bitch
fat bitch skinny bitch
Old 08/25/2013, 07:43 PM   #2
civicex_1134
civicex_1134's Avatar
civicex_1134 is offline
Default Re: Odd problem
if it were me id check both axels at both ends and make sure they're in all the way. i wld then double check to make sure the correct axels are in, (it sounds lame but i happen to slip the wrong axel in on the driver side and it did the samething). and sometimes if the axel doesnt "snap" into place on the mid shaft itll start walking out and cause the same issue. hope this helps. good luck
99 civic EX clover green, mini me SOHC-RIP
91 Integra GS, MR-sold
91 civic 4D-LS/Vtec, 75 shot-sold
91 Integra GS, champ white-sold
95 civic coupe, project car, turbo LS to be
Old 08/25/2013, 09:45 PM   #3
dat192
Honey boo boo
dat192's Avatar
dat192 is offline
Yes one axle tore a boot and it only does it in first gear so that's probably the problem there and second gear seems like it wants go pop out so I'm thinking throw out bearing is going out.
1 bitch 2 bitch
