Old 09/16/2013, 10:24 PM   #1
Default HEADLIGHT TROUBLES
Ok i have a 96 civic ex both headlights have always been working perfectly until now, for some reason the passenger side will not work, i thought maybe it was just a bad ballast or a bulb so i swapped the passenger side stuff to the driver side and driver side still works but passenger doesnt, ive looked all around for a loose wire or something, any ideas?
Old 09/17/2013, 09:13 AM   #2
LowNsloEJ6
1SickUA7
LowNsloEJ6's Avatar
LowNsloEJ6 is offline
Default Re: HEADLIGHT TROUBLES
fuse or bad ground. same thing happened to mine turns oout the under dash fuse was blown,
08 TL-S
97 EJ6 D16Z6
