Old 03/31/2014, 12:51 PM   #1
CorbinMB
CorbinMB's Avatar
CorbinMB is offline
Default Electric Problem, need Help
I have a 97 Civic LX Sedan, bought it with the front passenger window not working. Yesterday I took the door panel off to check if it was the motor. No power is going to or coming out of the motor, so I dont think it is a problem with the motor. The power locks work fine. No blown fuses. If anyone knows how or can fix it that would be great.
Old 03/31/2014, 02:13 PM   #2
Default Re: Electric Problem, need Help
Take a peek at the door harness.....primarily the outside part that clips into door. Sounds like you may have a broken wire from it. Seems to be very common on 2 and 4 door civics. Just pull back on the rubber piece over it and inspect that first....specially if locks all work since that harness distributes all functions to the other doors.
Old 03/31/2014, 03:20 PM   #3
CorbinMB
CorbinMB's Avatar
CorbinMB is offline
Inside this? Just cut it open?
Old 04/01/2014, 12:39 PM   #4
I would not suggest cutting.....just see if it will come off from the area where it goes into the door. Should only be a rubber sleeve covering the actual plug.
I will see if i have a picture of one to post.
Old 04/07/2014, 01:09 PM   #5
CorbinMB
CorbinMB's Avatar
CorbinMB is offline
Any good shops in the Des Moines area that wont over charge?
Old 04/22/2014, 08:31 PM   #6
CorbinMB
CorbinMB's Avatar
CorbinMB is offline
Someone fix this for me, its getting hot, and just found out my A/C doesnt work.
