Old 11/09/2014, 07:01 PM   #1
WhiteBoy
WhiteBoy is offline
Ques What do I need to make a z6 block run in my obd2
Okay guys I'm having some trouble with a few things on this swap, let me tell you what I got going on first!
96 ex coupe OBD2
New Z6 OBD1 block
Still running my Y8 head & intake as well as Dizzy
Problems
My head won't bolt down to the block
To keep the car OBD2 can I just use the jumper harness and the car will run or?
Old 01/18/2016, 10:04 AM   #2
Sofast
Sofast's Avatar
Sofast is offline
Default Re: What do I need to make a z6 block run in my obd2
To put the Y8 head on the Z6 block, you need 9 head studs/bolts from the Z6 and 1 from the Y8. That 1 stud goes by the vtec solenoid
