Old 01/24/2011, 11:19 PM   #1
prelude97
prelude97's Avatar
prelude97 is offline
Default Tranny prob! won't go into gear!!
FUCKKKKKK tranny went out today on me on the interstate!!!! won't go into gear now at all. not on or off!! clutch still has fluid and good foot pressure! just recently bled...like you normally can force a car into gear ya know??? but like you can't lol i also check the slave cylinder.. it moved a little bit i had to feel the movement but it wasn't much. any ideas guys????
Honda "Power of dreams"
Old 01/25/2011, 08:48 AM   #2
crxme
crxme's Avatar
crxme is offline
Default Re: Tranny prob! won't go into gear!!
probably your pressure plate teeth got bent out of place.
Old 01/25/2011, 04:50 PM   #3
probally not, pry your slave or master cylinder pooped on you
Old 01/25/2011, 08:45 PM   #4
95topless
95topless's Avatar
95topless is offline
when my slave cylinder went out there was no foot pressure at all.. had to pull the pedal back up
Old 01/25/2011, 11:06 PM   #5
prelude97
prelude97's Avatar
This would be ture. and thats not the case because both slave and master are working and clutch pedal is good. i got underneath today and wiggled around the linkage and really didn't notice anything wrong... its gott be in the trany bell or case so clutch or gears.
Any suggestions??????
Old 01/26/2011, 08:01 PM   #6
replace the throw out bearing and pressure plate than.
Old 01/26/2011, 11:53 PM   #7
prelude97
prelude97's Avatar
Yeah i'm getting it towed home tomorrow from cedar rapids. anyone got a pressure plate or throwout bearing for sale???
Old 01/27/2011, 02:30 PM   #8
prelude97
prelude97's Avatar
bump any more ideassss
Old 01/29/2011, 07:19 PM   #9
i say its the clutch. there should be the spring things on the clutch and mine broke and it wouldnt go into gear. if throw out bearing bad... you would hear a scratching noise when you step on the clutch. could be pressure plate too... or if you have a tranny leak then it also wont go into gear. check your axle gaskets... the circle rubber piece that the axle goes into the tranny. usually the spring behind it can easily get messed up and leak fluid. if theres not enough fluid it would also cause it not to shift into gear
Old 01/30/2011, 10:55 PM   #10
crxme
crxme's Avatar
crxme is offline
thats about exactly what i said on the first post....facepalm..
Old 01/31/2011, 10:57 AM   #11
prelude97
prelude97's Avatar
took out tranny and put back in 3 times. still nothing. i don't get it.
Old 01/31/2011, 01:08 PM   #12
gabebauman
DR. DIY
gabebauman's Avatar
gabebauman is offline
Bummer it didn't work for ya. Sorry man.
Old 02/01/2011, 03:42 PM   #13
prelude97
prelude97's Avatar
its all good. gsr tranny is very nice
Old 02/11/2011, 09:23 AM   #14
update?
Old 02/11/2011, 09:35 AM   #15
gabebauman
DR. DIY
gabebauman's Avatar
Originally Posted by deadmoans View Post
update?
He ended up getting a gsr tranny.
Old 02/12/2011, 11:28 AM   #16
prelude97
prelude97's Avatar
yeah thanks gabe. i did. idk i took it in and out of the car 4 times that weekend! put it back together perfectly... i'm not sure what was wrong with it i traded it. the gsr tranny is very nice tho!! thanks for all your help down at wrenches
Old 02/13/2011, 11:49 PM   #17
hflshane
hflshane's Avatar
hflshane is offline
it could have been your throttle pressure regulator valve. my tranny wouldn't shift when i had that problem too. stupid honda manual trannys...
Life Begins at 9000rpm
Old 02/14/2011, 09:34 PM   #18
prelude97
prelude97's Avatar
haha yep that was the problem. actually is was just the seat belt modual..weird
