Old 06/30/2011, 09:58 PM   #1
purpleheartapeed
purpleheartapeed is offline
Default h22a swap in a 97 civic help with ecu n harness
i am strugglin to find out wat year or model honda will fit the p28 ecu so i can get this ccar runnin. is a f22 wire harness fit it or do i have to find a 92-94 prelude which i cant where im at any helpor suggestions pllllllllllllllleeeeeeeeeeeeeaaaaaaaaaaaaassssssse eeeeeeeeeee
Old 06/30/2011, 10:58 PM   #2
Default Re: h22a swap in a 97 civic help with ecu n harness
OK, you will modify your original civic harness to fit the H22. Do not use any other harness. The 96-98 (and 99-00 use a slightly different harness) civics use a harness that connects directly to the ECU and also to the cabin harness. To use an OBD1 ECU, you will need a OBD2A to OBD1 jumper harness and hook it up to the original engine harness. Any other questions, post here.
Old 07/01/2011, 12:07 AM   #3
P98
P98's Avatar
P98 is offline
LT1 T/A
Old 07/01/2011, 02:31 PM   #4
Exactly what this man said.
