Old 11/01/2011, 07:02 PM   #1
ej2(93civic dx)
ej2(93civic dx)'s Avatar
ej2(93civic dx) is offline
Default h22 swap in to 93 dx
ok so i know a few people have civics with the h22 swap in them and have bee looking all over and have come across a few threds that said h22 have a few issues going into civics like the unibody bending because of power are thies things true or just thinfs that happened because of poor builds i am also curious on the h2b would i still have to weld new mounts or can i sue the stock mount and curious on some good sugestions of aftermarket parts such as cams maybe some opinions on how to get the most power out of a h22 n/a also turbo or sprayed i would also like to see pictures of others that have h22 swaps so pleas feel free to poast i have not started mine but will poast pics after i start my build
1993 Honda Civic DX Coupe Ej2
Old 11/01/2011, 07:47 PM   #2
Pancho
Pancho's Avatar
Pancho is offline
Default Re: h22 swap in to 93 dx
I believe and I've heard that you need to get a good firm front suspension.. H22 are heavier and good HP so the suspension needs be tightened up.. Again not sure so someone correct me if I'm wrong.. And I would personally boost
92 Civic Hatch SI [Sold]
92 Talon Tsi AWD[Sold]
93 Civic Hatch SI [Sold]
Old 11/01/2011, 08:32 PM   #3
ej2(93civic dx)
that is what i am leaning tword i have seen on youtube good numbers for boosted h22s what are good set ups for boost! and all opinions are welcome again
Old 11/02/2011, 05:09 PM   #4
ej2(93civic dx)
is there no one els that has an opinion on this matter
Old 11/02/2011, 07:46 PM   #5
As far as an H22 in another chassis, the biggest problem I have with them is the axle angles are all wrong. That was one of the purposes behind the H2B setup. Use the B series transmission in its original location along with a standard B series mount and attach it to an H22. Keep the stock B shift linkage, basically, everything you need to do a B series in your chassis, but with an H22 powerplant.
As far as boosting an H22, if you want anything more than moderate power, you are either going to build a sleeved block or look at using Mahle Gold Series pistons in it. The H22 sleeves are made of a material called FRM. It is not really compatible with forged piston setups.
Old 11/03/2011, 03:07 PM   #6
ej2(93civic dx)
thanks foy your input but i herd with the h2b set up like some of the greas are not long enough to get max power out of
Old 11/03/2011, 04:18 PM   #7
No, actually, going to the B-Series transmission has given greater flexibility to putting power to the ground between both all motor and turbocharged setups. There is also the aftermarket availability of gearcases and gearsets to hold substantial amounts of power. I personally was going to run a gsr trans for my boosted H2B setup that I abandoned. They also tend to put more power to the wheels through a B transmission than an H transmission. The H2B is just a proven setup. Current fastest is Reid Lund from Kaizenspeed having run into the 8.7x's at over 170 mph in an Outlaw class car.
Old 11/03/2011, 07:08 PM   #8
ej2(93civic dx)
so then what b series trans is best for boost on stock trans?
Old 11/03/2011, 10:10 PM   #9
GSR, all you will need.
Old 11/06/2011, 12:02 PM   #10
ej2(93civic dx)
i am sorry i guess that i am confused because i herd the gsr trans put out more tq but has shorter grears witch in turn isnt good for boost because you dont get to hit full boost because you have to shift to soon? is that not corect what is the highest rpm you can go with stock gsr trany
Old 11/06/2011, 09:30 PM   #11
I have turned my completely stock GSR transmission to 9200 RPM and have been able to change gears without a problem. You can make it turn 140+mph at the top of 4th depending on tire size and engine RPM. Whatever you are reading or hearing is incorrect. Stock GSR transmissions have run mid 9 second passes with many of them topping 150mph...in 4th gear. Neither Eric nor myself have reached the limit of the stock transmissions yet. I have almost 20mph I can go in 4th gear before I hit the limiter, and I trapped at 130mph.
Old 11/07/2011, 12:15 PM   #12
ej2(93civic dx)
ok thanks any other input on this topic picking up motor soon would like as many peoples input as possible befor i perches motor
Old 11/07/2011, 09:04 PM   #13
Just so you know, there is a ton of work that needs to be done for an H2B setup. It is about as far from a drop and go swap as a K-series is, and maybe even further. I personally went with the QSD (QuarterSportsDrag) kit, and would purchase it again in a heartbeat. I do not like the EVO/Bisimoto kit. I don't like that you can't use standard B-series mounts, that you have to use theirs. I also don't like that they sacrificed axle angle to get the hood to close like stock. That is the whole point of doing the H2B, keeping the stock axle angle. If you do decide to go H2B and you have any questions, do not hesitate to ask. I have done it (albeit for a short time), but I did all the hard work, and I know my way around pretty much anything Honda.
Old 11/10/2011, 04:59 PM   #14
ej2(93civic dx)
thanks for the imput i am pritty firm on the swap so i will be intouch do you know how to do the wireing
Old 11/10/2011, 06:45 PM   #15
The wiring is pretty straight forward for your setup. Extend the alternator wiring and add VTEC wiring. Also have to do some work with the external ignition coil depending on your distributor. Other than that, not much comes to mind.
