Old 02/10/2012, 11:57 AM   #1
J~RUS~09
J~RUS~09's Avatar
J~RUS~09 is offline
Default ls/vtech
I have decided that i am going to take the path of a ls/vtech
i have found a head that i am getting,
i need the fallowing parts.
b16 dizzy
ecu
and ls/vtech conversion kit
Build it with your own 2 hands
Old 02/10/2012, 01:08 PM   #2
Default Re: ls/vtech
b16 dizzy
ecu
Good for you...
what did you want people to say?
Did you have a question somewhere in that post?
Old 02/10/2012, 04:02 PM   #3
That is probably the worst motor set up you could go with. Also it's spelled *vtec, there isn't an H on the end.
Old 02/11/2012, 01:34 AM   #4
What is wrong with a good ls/vtec setup?
Old 02/11/2012, 02:09 AM   #5
dalawoi
toaster box
dalawoi's Avatar
dalawoi is offline
i think he wants it moved to wtb section? or do u need 25 for that to?
2012 kia soul
1993 mirage ;)
Old 02/11/2012, 02:17 AM   #6
luis31
Jefe De Jefes
luis31's Avatar
luis31 is offline
That's what I'm wondering
Old 02/11/2012, 01:57 PM   #7
Properly done there should be no issues. Making 500+ on stock sleeves, and no problems. All about buying the right parts and being careful in your assembly, but that goes with everything.
Old 02/11/2012, 02:39 PM   #8
mycarslow
mycarslow is offline
That car won't be turboed he just wants a nice lsv to drive around and have some fun
Built h22 62mm turbo e85
Old 02/11/2012, 05:52 PM   #9
Sorry, I was talking any sort of LS/VTEC reliability. Your oil supply, headgasket, proper tune, are all important when doing something like that. Base your bottom end work off of the mileage and abuse the LS bottom end has already been through. New bearings, rings, ARP rod bolts.
Old 02/11/2012, 07:13 PM   #10
4DRLX
4DRLX's Avatar
4DRLX is offline
Is proper ls/vtec even worth it compared to a basic motor swap.
Old 02/12/2012, 12:41 AM   #11
luis31
Jefe De Jefes
luis31's Avatar
luis31 is offline
Yep. IMO
Old 02/13/2012, 05:39 PM   #12
I should learn to be more clear when I talk. If done the right way (which nobody ever seams to do anymore) then it's a good motor. If you slap a b16 head on an LS block then no...it won't last.
Old 03/18/2012, 10:05 AM   #13
TOTO
TOTO is offline
correct
Doing a ls/v takes a while and is a long process. (i just did one) There is lots to consider like how high your going to rev it, Longevity, budget. I would throw budget out the there as it is nice to not worry when you rev to 8k LOL
Dont forget to add arp headstuds and rod bolts as they are not the strongest. if you buy eagle rods, then you can fit a better bearing and allow for better revving. but remember,a ls or a b20 block was not ment to rev that high... so look into balancing the crank also.
Ill let that info pick your brain some more
1994 Bmw 325i M3 Swap Dinan Special
1997 Civic Ex B20v Turbo.
Old 04/23/2012, 09:32 AM   #14
Bmwz389
Bmwz389's Avatar
Bmwz389 is offline
I'm currently building one too. Treat it just like every other important engine build, why put money into something that wont last? Here's some reference I've followed, 95% of this info has been proven with many builds.
http://www.honda-tech.com/zerothread?id=1676914
Here's a listing of parts:
http://www.honda-tech.com/zerothread?id=1812388
Hope that helps.
Alot of the problem resides in the R/S ratio, and those teeny tiny connecting rod bolts from factory. It'd be best to run a GSR girdle, but at that point you might as well do a full GSR swap
It's a good read
- Brandon
