Old 02/29/2012, 09:18 PM   #1
turboteggy
turboteggy's Avatar
turboteggy is offline
Default B20b into 95 integra gsr
Hey guys I've searched a little on this topic but haven't seemed to find what I Need. I am going to be putting a b20b into my integra just wanna know everything I'm gonna have todo to make it work. Any advice is apreciated thanks.
when the turbo spins the bullshit ends.
VTEC all day!!! well till you run out of oil.
Old 03/03/2012, 02:50 PM   #2
turboteggy
turboteggy's Avatar
Default Re: B20b into 95 integra gsr
Come on guys nothing?
Old 03/04/2012, 09:22 AM   #3
4DRLX
4DRLX's Avatar
4DRLX is offline
bolt it in and go? both are obd2? i believe u gotta use a b16 or b18 tranny tho
edit: ill ask my buddy noah he did one in a dc integ a while back
Old 03/04/2012, 10:33 AM   #4
94integraguy
94integraguy is offline
U can use your gsr tranny it will have short gears. But there's really nothing u need drops right in and goes. Now I know that the Integra driver side mount won't work for me when I did it do I got one from a 92-95 civic and it bolted right in.u will need a ls ecu to I don't think your gsr one will work.
Old 03/04/2012, 12:02 PM   #5
turboteggy
turboteggy's Avatar
I thought all b series mounts were the same?
Old 03/04/2012, 12:17 PM   #6
If you take the mounting post off of the existing engine, you can use your existing mounts. You will have to use your existing transmission, and linkage. You will need to make sure it does not have the taller SUV style plenum. If it does, you will need to replace it with an LS intake.
Old 03/04/2012, 02:04 PM   #7
I wanna know if you have gsr already in It n your swapping it out for a b20
Old 03/04/2012, 03:33 PM   #8
turboteggy
turboteggy's Avatar
I'm swapping it because I need something to drive while I rebuild the gsr. It was the smaller intake mani on it but I don't have throttle body. Could I maybe swap the intake mani form my gsr or maybe just the throttle body?
Old 03/04/2012, 06:32 PM   #9
You can use the throttle body off of your GSR to put on the B20. That will be ok.
Old 03/06/2012, 12:39 AM   #10
slut cakes
slut cakes is offline
you wont be able to swap the intake mani off the gsr an put it on the b20. but can use the tb
Old 03/10/2012, 09:42 AM   #11
turboteggy
turboteggy's Avatar
Thanks guys will the injectors and fuel rail work too? i only have a weekend to get this done so i wanna make sure this goes as smooth as possible.
Old 03/10/2012, 10:08 AM   #12
Keep the injctors and fuel rail off of your GSR. Double check the bolt spacing on the B20 IM.
