Old 04/14/2012, 10:33 PM   #1
mattcossel29
jackstand ballin
mattcossel29's Avatar
mattcossel29 is offline
Default f23a1 to obd 1 problems
l am having issues fixing the obd1 swap on my cb7. l have a p28 ecu, two of them actually to verify the ecu is good. The engine is in limp mode and throwing a CEL, but when l use the jumper to read the codes it does not flash any codes. l have verified l am doing this right because l have already fixed a code six by replacing the CET sensor and resetting the ecu. The engine is missing and idling very poorly, but when driving it is fine besides being in limp mode.
Any help would be much appreciated
Old 04/14/2012, 10:49 PM   #2
LowNsloEJ6
1SickUA7
LowNsloEJ6's Avatar
LowNsloEJ6 is offline
Default Re: h23a1 to obd 1 problems
Are the ECU's chipped?
08 TL-S
97 EJ6 D16Z6
Old 04/14/2012, 11:06 PM   #3
mattcossel29
jackstand ballin
Whoops, should have mentioned that. No they are not.
Old 04/14/2012, 11:15 PM   #4
mattcossel29
jackstand ballin
probably my idle issue:
http://honda-tech.com/showthread.php?t=2743048
Old 04/14/2012, 11:22 PM   #5
mattcossel29
jackstand ballin
Oh, and l also tried a POA ecu and it ran a lot worse than with the P28.
Old 04/14/2012, 11:26 PM   #6
mattcossel29
jackstand ballin
Ah, from what l read l need to have my p28 or poa chipped and tuned.
http://www.cb7tuner.com/vbb/showthread.php?t=137399
http://honda-tech.com/showthread.php?t=2473747
http://honda-tech.com/showthread.php?t=2919809
Old 04/16/2012, 09:46 AM   #7
Yes you deffinately need to tune it! Which injectors are you running in it? I imagine if you are running the H23a1 injectors that it is extremely rich.
www.roskoracing.com
Old 04/18/2012, 11:39 AM   #8
94integraguy
94integraguy is offline
U should try a p14 ecu for it. Me and my buddy are big accord guys hit me up with a pm we could come help u out.
Old 04/19/2012, 01:24 AM   #9
4DRLX
4DRLX's Avatar
4DRLX is offline
Default
Yea ill come check it out. First step is to eliminate any potential problems. P28 isnt made for a h23. If u cant get a p14 maybe try a stock accord ecu. Since they use same size injectors. Also did u reset the ecu? Pull your back up radio fuse 7.5a also are you COMPLETELY sure your vacuum lines are correct? My old lude miss fired due to incorrect placed lines. 515-669-8035 call or text me if needed.
Old 04/19/2012, 01:28 AM   #10
4DRLX
4DRLX's Avatar
4DRLX is offline
Default
Also your title confuses me h23a1 is obd1 your car is obd1.
If what i said above doesnt help. Text me ill come check out sometime.
Old 04/19/2012, 01:39 AM   #11
4DRLX
4DRLX's Avatar
4DRLX is offline
Default
So try a pt6 from cb7 ex or se.. the ones with the f22a6
Old 04/19/2012, 07:53 PM   #12
mattcossel29
jackstand ballin
Wow, I failed with the thread title.it is a f23a1. I will change that.
Old 04/19/2012, 08:10 PM   #13
mattcossel29
jackstand ballin
Default Re: f23a1 to obd 1 problems
Oh, and I am not sure on the lines, this is some one else's project I bought.
Old 04/24/2012, 01:39 AM   #14
4DRLX
4DRLX's Avatar
4DRLX is offline
so you have a f23a1 in a cb7?
why? i mean its not a bad swap but not very common.
so ill tell you you cant use a stock cb ecu you need a sohc vtec ecu..
go get a ecu from a cd5 that has the vtec motor in it.. ecu is called POA
Old 04/24/2012, 01:45 AM   #15
4DRLX
4DRLX's Avatar
4DRLX is offline
still have your p28? put it in and check firing order
f23 firing order
also f23 is obd2 cb7s are obd1 did you convert it properly? or can verify previous guy converted properly..
why did he end his project and sell to you was it because of the issue u have now?
anyway check the firing order
Old 07/31/2012, 02:43 AM   #16
ekilinck
ekilinck is offline
Tag Re: f23a1 to obd 1 problems
Well, This ecu chip tuning tool may help. I have used it before, and it is really useful.
Instruction, Code and Car List
