Old 04/26/2012, 12:34 PM   #1
like a sumbody
like a sumbody's Avatar
like a sumbody is offline
Default problems with gsr swap
ok so i just swapped a gsr into my 92 hatch and it starts and everything and idles but when the car gets to running temp it dies and wont start unless i hit the gas and help it stay alive i have tried doing the research and cant come up with anything if any1 can help plz let me know
Old 04/26/2012, 03:20 PM   #2
Default Re: problems with gsr swap
Try checking fuel filter or maybe. Even injectors. I say try a bottle of seafoam into the gas tank and see if that helps. 10 bucks or so at autozone. But don't forget to add gas with a full bottle.
If its your fuel filter or injectors.... it should help clean it a little bit.
Old 04/27/2012, 01:53 PM   #3
H22CB9
H22CB9's Avatar
H22CB9 is offline
Check your tps, map sensor, or your dizzy there is a sensor in your dizzy if its going bad once it gets warmed up it will act up I had the same problem in my ls swapped ef hatch I replaced the dizzy and it fixed it does it cut out at when u drive it
Old 04/27/2012, 02:54 PM   #4
like a sumbody
i took the car to central imports hopefully sean can get it going
