Old 05/02/2012, 01:49 AM   #1
EJ8jay
EJ8jay's Avatar
EJ8jay is offline
Default DC2 auto to manual
I just swapped (with help) my dc2 to a manual and the key won't start the car. I have everything plugged in I didn't change ecu or wiring I glued interlock switch to park so the ecu would read it was in park. Yet I turn key and nothing happens I jumped the starter so I know it works but why wouldn't the key start it. Is there a plug in the engine bay that needs bridged? There are two plugs by trans plug that aren't plugged in as well as another by the passenger side light. Please help (btw car doesn't go into gear with the car on replacing clutch and bearings so I figure that will fix that issue.)
It's Leopard MAN!!!!!
Old 05/02/2012, 02:11 AM   #2
P98
P98's Avatar
P98 is offline
Default Re: DC2 auto to manual
Have the ground that goes to the trans from the body connected?
LT1 T/A
Old 05/02/2012, 06:17 AM   #3
Jason, did you get any of my text messages I sent? Lol. As far as the key problem i am still looking into it....one key factor here is you also need to change ecu to a manual ecu or you'll get an engine check light and a funky running car. When replacing that clutch you will need to do the following to ensure driveability for a couple years, as opposed to a few months.
Flywheel needs to be resurfaced at a machine shop (city brake on 9th does great work)
All bolts on flywheel and pressure plate need to have Blue Loctite and torqued to specs
If you buy an new clutch kit it should have he following (pressure plate, guide tool, disk, throwout bearing (or release bearing) and the pilot bearing which goes to the flywheel after it has been machined). By taking these steps you are making sure EVERYTHING is new and ready. If you skip any of these parts or procedures, I can assure youll have a really bad time with that car.
Old 05/02/2012, 08:31 AM   #4
You maybe can get a away with not doing this. But your risking alot. When its simple to get gone. An its alot safer. Flywheels can explode an you would be saying goodbye to ur Tranny. Possible even hurting yourself. If you dont resurface your flywheel heat cracks can form alot faster an warping can happen. An that can lead it to breaking. I've seen it happen one time to a srt-4 that was lining against me heated up his tires. An boom trans was destroyed wasn't even connected to the motor anymore Lol.
Old 05/02/2012, 09:16 AM   #5
LowNsloEJ6
1SickUA7
LowNsloEJ6's Avatar
LowNsloEJ6 is offline
What year is the car? Is it equipped with an immobilizer. When i did my auto to manual I completely eliminated the gear selector and just. Soldered 3wires together
08 TL-S
97 EJ6 D16Z6
Old 05/02/2012, 01:14 PM   #6
EJ8jay
EJ8jay's Avatar
EJ8jay is offline
So what exactly am I machining just cleaning the surface? Also it's a 1994 it should not have an immobilizer. I do have all grounds properly connected. I even tested continuity to all of them. I can say the ecu thing is correct cause it acts like the IAC valve is dirty now like an erradic idle. lol the key should still come out of the damn car. I'll have a CEL anyway cause I can't find the clutch plug ins inside the car so my clutch switches wouldn't be connected anyway so yeah. I'm not really worried about the CEL right now more concerned about just making it work then cleaning up minor issues in the extremely near futute.
Old 05/02/2012, 02:06 PM   #7
The machine part will be for the flywheel do it is fresh...it'll take layers off it to make sure that both its surface and disk surface are new and won't cause heat soaking and all other problems associated to flit h issues.. after all is installed, you will need to do a break in period of about 500-600 miles of stop and go driving (no highway miles).
Old 05/02/2012, 02:10 PM   #8
EJ8jay
EJ8jay's Avatar
EJ8jay is offline
lol the stop and go driving shouldn't be a problem so who wants to help me break it in lol what stop lights are quarter mile apart hahaha jk..
Old 05/02/2012, 02:25 PM   #9
LowNsloEJ6
1SickUA7
LowNsloEJ6's Avatar
Did u swap from a 3 wire IACV to a 2 wire??
08 TL-S
97 EJ6 D16Z6
Old 05/03/2012, 04:34 PM   #10
I believe the only iacv that has 3 wires is the y7 and auto y8.
Old 05/22/2012, 12:58 PM   #11
EJ8jay
EJ8jay's Avatar
EJ8jay is offline
So the only gear it will go into is third with the car on the car drives just wont go into any other gear got my boy Rodney coming tonight keep ya posted.
Old 05/22/2012, 11:18 PM   #12
So the only gear it will go into is third with the car on the car drives just wont go into any other gear got my boy Rodnie coming tonight keep ya posted.
You forgot to mention....problem solved....lol....and I corrected my name....its ie not ey....lol ha ha
Just needed some adjustment on the pedal push rod as suggested by our good friend Mr. Chad Gates. It was the only thing left to check.....lol.
Now, my question is: Did you drive it after I left?
Old 05/28/2012, 11:23 AM   #13
NikkyT
NikkyT's Avatar
NikkyT is offline
yessir, but we have to figure out this key issue!!!!
Old 05/28/2012, 11:45 AM   #14
EJ8jay
EJ8jay's Avatar
EJ8jay is offline
No I now have a charging issue I put a good alternator in it the battery was supposedly new I've tested both yet it won't charge wtf?
Old 05/28/2012, 02:21 PM   #15
Check your wiring. Make sure the plug into the alternator is plugged in good. Any cel?
