Old 07/18/2012, 04:13 PM   #1
D.Smith
D.Smith is offline
Default lost spark!!
i lost spark while driving saturday, any ideas what might of happened???
its a 99 civic with a b18b swap car has been converted to obd-1
Old 07/18/2012, 07:32 PM   #2
Default Re: lost spark!!
ICM or coil would be the first two things I would test/replace.
Old 07/18/2012, 09:53 PM   #3
D.Smith
D.Smith is offline
already tried the coil and thats not it
Old 07/18/2012, 10:58 PM   #4
The ICM (ignition control module) is what tells the coil when to spark based on the signal from the ECU. There is a diagnostic for it floating around. They are pretty much all the same. If it has the same mounting points, it will work if you are swapping one from another distributor.
Old 07/18/2012, 11:59 PM   #5
D.Smith
D.Smith is offline
thanks ill change it out in the morning
Old 07/19/2012, 03:25 PM   #6
D.Smith
D.Smith is offline
ok so i changed it out and still nothing
Old 07/19/2012, 03:54 PM   #7
Have you gone about doing any troubleshooting? Checking to see if you have 12v, continuity and ground where you are supposed to. Checking the resistance on the +/- and windings on the coil. Did the coil and ICM come out of a KNOWN working distributor?
Here is a great troubleshooting source
Old 07/19/2012, 03:59 PM   #8
D.Smith
D.Smith is offline
all the grounds r their, its getting fuel cause i can smell it and yes it was a working dizzy
Old 07/19/2012, 04:28 PM   #9
Then run through the troubleshooting on that link, and find the source of your problem.
Old 07/19/2012, 04:34 PM   #10
D.Smith
D.Smith is offline
ill have to wait till i can get someone to help me
