Old 02/23/2013, 10:47 PM   #1
omahaspick2011
omahaspick2011's Avatar
omahaspick2011 is offline
Default 98 civic sedan d16y7 to b18a1 help first time
This is my first time doing a swap that involves
Removing the sohc and replacing it with a dohc.
I have a d16y7 with hydro trans and I'm replacing
It with a b18a1 with a cable trans. Can some one
Please give me a step by step on how to do it and
What I need. I have the full swap b18a1 with trans
Ecu harness axels shift linkage and stock motor
Mounts any help out there
Building B series with boost sorry single cam.
lol
Old 02/24/2013, 10:54 AM   #2
omahaspick2011
Default Re: 98 civic sedan d16y7 to b18a1 help first time
Does anyone know
lol
Old 02/24/2013, 11:23 AM   #3
omahaspick2011
My d16y7 is obd2 the motor I'm putting in is b18a1 that is obd0 I have the whole swap with harness is there anyone that can help
lol
Old 02/24/2013, 09:06 PM   #4
Well, sounds like you may be missing a few things. You need a hydro to cable mount and a hydro to cable adapter for the clutch actuation. You also need an 99-00 SI rear T bracket. You will also need to change your IACV from 3-wire to 2-wire. Get an OBD2 distributor, to use with the factory harness, or an OBD1, and use it with a conversion harness. What ECU are you running?
Old 02/25/2013, 08:51 AM   #5
michaelx43
michaelx43's Avatar
michaelx43 is offline
pr4, I think he can use obd1 p75 ecu with his civc stock harness and modify plugs on the obd0 motor and use a jumper harness.
Old 02/25/2013, 10:34 AM   #6
omahaspick2011
Default Re: 98 civic sedan d16y7 to b18c1 help first time
If I use the cable trans do I need to swap my clutch pedal
lol
Old 02/25/2013, 03:30 PM   #7
Here is what you need to run that cable transmission in your EK chassis.
CLICK HERE AND BUY THIS I would also check with JB and see if they carry the adapter mount for this swap.
Old 02/25/2013, 03:40 PM   #8
If he is using an OBD2A to OBD1 ecu adapter harness, he can use a P75 to run it stock. He could also use a P05/P06/P28/P30/P72 ecu that is socketed and chipped for an LS basemap. I would try and locate an OBD2 LS distributor. It will make the plug and play easier, and limit the amount of wiring you need to do. Inexperience when it comes to distributor wiring can be a nightmare. More than once have I seen it lead to somebody selling a car, when all it needed was an experienced set of eyes and a half hour of time.
Old 02/26/2013, 09:37 AM   #9
Shhh.... i am.waiting so.i can buy his car for cheap lol. Jk
Better off finding hydro trans. Find an obd2 ls intake manifold to make things easier.
Convert from 3plug iacv to 2 plug.
Then get obd2 distributor on it. Ls non vtec will mount up.
99 si back t bracket.
B series axles with matching trans axle.
Example... da axles calls for da trans axle. Dc with dc.
Da have male male ends on.both sides vs dc has female male on the axle on left side.
For the harness. Just use your stock harness and change out any necessary sensors so the plugs match with obd2 harness.
Next get a jumper harness for ecu. Obd2A to obd1. Use obd1 p75 or obd1 pr4 ls ecu. I would go with the pr4 obd1 ls.
Obd1 pr4 only came in the 92- 93 integras.
Old 02/26/2013, 09:40 AM   #10
Btw. U can find ls hydro trans for couple hundred bucks.
Instead of buying the conversion kit...
Sell the cable trans and use that money with the money for buying the conversion kit to pick up the hydro trans.
Around the same cost and less headaches
Old 02/28/2013, 08:38 PM   #11
omahaspick2011
Thanks for all the input
lol
Old 03/21/2013, 02:12 PM   #12
whitsingleslamer
whitsingleslamer is offline
I got a pr4 ecu and obd2a to obd1 jumper for sale
1998 White civic ls swapped sold
1997 ford f150 current
1998 gsr integra current
