Old 04/30/2013, 12:18 AM   #1
tgross1994
tgross1994's Avatar
tgross1994 is offline
Default B20/b16
What do you guys think about puting the b16 head on the b20 block? Do it make for a decent power plant or is it better to go b16 all the way?
Old 04/30/2013, 07:43 AM   #2
Default Re: B20/b16
Oo for sure b16 all the way. They use a lot more oil and gas but its worth it.
Old 04/30/2013, 02:23 PM   #3
tgross1994
tgross1994's Avatar
Default Re: B20/b16
Itd be going in a da integra so b16 over the b20/16? I have farther intentions of boost for it too, my buddy has a b20 civic ex and he loves it. I like the b16 but he sugguested the b20/16 for a powerplant
Old 05/03/2013, 06:37 AM   #4
jh4dc
jh4dc's Avatar
jh4dc is offline
Default Re: B20/b16
B20/B16 will provide more torque than the 16 alone however the 16 has shorter stroke so it tends to be more reliable when you redline at high rpms. If you boost either that's another story It all just depends on your build
Old 05/03/2013, 08:52 AM   #5
Default Re: B20/b16
if your gonna go for boost imo build the b20 set up, its way more torquey of a set up an can be just as reliable of a set up,
Old 05/03/2013, 09:31 AM   #6
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
ConHuevos! is offline
Default Re: B20/b16
B16B and call it a day.
Sri Sri Ravi Shankar
Old 05/03/2013, 04:03 PM   #7
Default Re: B20/b16
can say i wasnt very impressed at all with my b16,
Old 05/05/2013, 03:01 PM   #8
pico4130
pico4130's Avatar
pico4130 is offline
Default Re: B20/b16
B20 was not meant to handle the revs like a B16.I bet it would be a fun motor while it lasted though. The cylinder walls on a B20 are thinner also, so its not a prime candidate for boost.It's basically a B18 with the cylinder bores punched out.I drove an Integra with a stock B20Z for a while and the extra torque did feel nice though.
Old 05/05/2013, 04:48 PM   #9
Default Re: B20/b16
my friend has a b20turbovtec set up an i think it revs pretty high?
Old 05/05/2013, 08:01 PM   #10
Default Re: B20/b16
Also not a stock bottom end in that car.
Old 05/05/2013, 08:04 PM   #11
Default Re: B20/b16
Nah its a pretty built car, will b pushin around 500hp+ soon.
but why build a b16 when u can a pay a little extra an go b20 an have a little more torque?
If im way wrong, im sorry idk a whole lot about them but this is what ive gathered
Old 05/05/2013, 08:16 PM   #12
Default Re: B20/b16
It all depends on end goal and current budget. Personally, I would go with an LS bottom end over the B20. Stock sleeves can take some power. B20, not as much. Thinner sleeves, not as much around them for support.
Old 05/06/2013, 02:09 PM   #13
onebad636
onebad636's Avatar
onebad636 is offline
Default Re: B20/b16
Agreed! I'm running an LSV that was actually finished by Mike, and I'm super happy with it. I'm only putting down 205/140 at the wheels, but it's also a mild build. As long as the motor is built by someone reputable or if you take your time and do it right, reliability isn't going to be an issue.
Old 05/06/2013, 03:17 PM   #14
Default Re: B20/b16
Adi did all the heavy lifting on that one. But I was more than happy to help out and finish it up. I agree though, a proper setup is only as good as the time and money spent on it.
Old 07/25/2013, 12:47 PM   #15
H22CB9
H22CB9's Avatar
H22CB9 is offline
Default Re: B20/b16
I like the ls-v in my personal opinion I wouldn't boost a b20/b16 setup for the fact of the b16 head by it self jumps the compression up and high compression+boost=booooom lol. unless you are gonna do bottom end work id stay N/A
Old 07/26/2013, 02:24 PM   #16
Default Re: B20/b16
assuming it's just stock rods/piston/sleeves, and all using decent size 57trim turbo, e85 decent tune with decent margin of saftey
stock b16 250-325whp
stock LS 250-300whp
stock LSV 350-400whp
stock b20v 350whp
CNC Werx
team4piston
Jordan Tuned
Rocket Motorsports
Modern Automotive Performance
Old 12/02/2013, 06:51 PM   #17
99TegB20
99TegB20's Avatar
99TegB20 is offline
Default
B20/b16 isn't a bad setup I you want to spend some money building the bottom but if your just wanting to just throw it together then your going to run into some issues I've had oil leak issues multiple times on my b20/v so I'm just running a straight b20b w/ a Type R transmission and it's decent for a daily
