Old 04/11/2011, 08:06 PM   #1
jdmcb3si
jdmcb3si is offline
Default In need of a little help
I'm boosting my NA EJ22e and need a little help/advice/direction on buttoning it up.
So far I have:
TD04L turbo with stock wastegate
Ebay header/uppipe combo
Ebay downpipe
WRX TMIC
Turbo XS rfl bov
I'm wanting to go 8 psi for now. I have 02 wrx blue injectors (not sure if they'll fit) if I need to up the fuel and will purchase a walbro as well.
My biggest fall back is engine management. I have posted on NASIOC and RS25 but noone wants to answer even though I've searched til my fingers bled and my head hurt. What should I use. I don't wanna go with the safc hack so I'm looking more at piggy back systems.
I also need to know what I missed on my parts list.
Old 04/12/2011, 07:40 AM   #2
Pandaimpreza
Pandaimpreza's Avatar
Pandaimpreza is offline
Default Re: In need of a little help
Is your EJ22E maf or map? If its a map then you will need a rrfpr. EJ22E's can run 8psi tops with stock internals. I'm only running 6psi on my EJ22E which is a 97 maf. I would get a Greddy Emanage Ultimate for a stand alone.
Old 04/12/2011, 03:20 PM   #3
jdmcb3si
jdmcb3si is offline
Its a MAF. Mine is a 98. I've been told its actually both map and maf.
I have been looking at the emanage. I want something that's user friendly.
Old 04/12/2011, 07:24 PM   #4
Pandaimpreza
I'm running a Apexi SAFC2 with a 98RS Ecu to bump up my rev limiter. I hear good things about the Greddy Emanage Ultimate. Your car will not like the atmospheric bov. I have a turbo XS and had to use the SAFC2 to adjust deceleration air to prevent stalling.
Old 04/13/2011, 10:12 AM   #5
jdmcb3si
jdmcb3si is offline
I was told oppsosite. That the bov would be fine atmosphericly vented.
I don't want the safc hack because there's no timing control. I plan on gong higher in boost later on so I want full engine management.
