Old 09/25/2011, 11:17 PM   #1
lulzcow
lulzcow's Avatar
lulzcow is offline
Wrench Bad Timing on my Legacy
From the noises my engine is making, I can only assume the timing is off.
When I bought the car, it was a piece. It is a 1997 Legacy L wagon with the 2.5GT motor swapped in, which came with an MSD coilpack and wires, a DIY intake, and WRX exhaust. Since purchasing it (with the help of a friend), I have replaced intake manifold and throttle body gaskets, fixed all vacuum and fuel leaks, put the 2.5 ECU in, added upgraded WRX headers, a Weapon-R intake designed for the motor, and a few suspension mods.
For a while, everything seemed right on the car. Then this ticking noise popped up. It is in sync with the RPMs of the motor. I am just curious, is there anyone around Des Moines that could check this out for me (as I am still learning, and don't want to fudge this up), besides the Subaru dealership?
Also, does the assessment of it having bad timing seem correct, or might I be looking at a more sinister internal issue?
Old 09/26/2011, 11:20 AM   #2
Default Re: Bad Timing on my Legacy
is the ticking sound closer to the valve covers or does it sound like it is coming from below....around crank? The noise (could) possibly be rockers/lifters loose since you say it is with rpm as you rev up etc. Not sure if that could be correct diagnose but it is a start.
May need to search on other forums for similar noise/issue.............could help at least pin point a rough area.
Old 09/27/2011, 08:54 PM   #3
lulzcow
lulzcow's Avatar
lulzcow is offline
Hey I appreciate your input! The guy who built my motor is in the Subaru club, said it sounded like the hydraulic lifters. When I can get him to, we are going to replace the lifters. And that is a very similar diagnosis to what the Subaru forum guys offered. Thank you for the input, this gives me hope that my engine won't blow up...anytime soon.
The noise definitely seemed to come from towards the bottom/mid of the motor. Took a while to pinpoint.
Haters gon' hate
Old 09/29/2011, 11:29 PM   #4
mattcossel29
jackstand ballin
mattcossel29's Avatar
mattcossel29 is offline
These are nice for this sort of thing!
http://www.amazon.com/Mechanics-Stet.../dp/B000RB5WQY
If it is coming from the middle or bottom of the engine it could be piston slap or rod knock.
Old 10/10/2011, 11:51 AM   #5
lulzcow
lulzcow's Avatar
lulzcow is offline
relatively good news. i had recently had my oil changed, and was lazy and went to a place to do it. they only put like 1 qt in. filled her up with royal purple and problem solved.
Haters gon' hate
