Old 08/19/2011, 01:16 AM   #1
crvtec54
crvtec54's Avatar
crvtec54 is offline
Default impreza no start issues
So i have a 95 impreza coupe project that needed timed up. I lined up the timing notches and went to start it but it just cranks and sputters a little like it wants to start but wont. Its getting fuel and spark. Tested the TPS, crank senser, and cam sensor and all tested fine. What am i missing? its driving me crazy.
Old 08/19/2011, 07:49 PM   #2
crvtec54
crvtec54's Avatar
crvtec54 is offline
Default Re: impreza no start issues
anybody?? im desperate.. need it fixed.
Old 08/21/2011, 11:53 PM   #3
JDMxTAi
JDMxTAi's Avatar
JDMxTAi is offline
Try cleaning Idle Air Control
Try a new MAF
Since it sputters it's a fuel problem.
I would say leaking injectors, could of caused a cylinder to flood but I don't think boxer motor floods
CEL?
1996 Honda Civic EX Coupe - Blown & Sold
2011 Nissan Rogue SV AWD - DD
Old 08/26/2011, 09:28 AM   #4
Pandaimpreza
Pandaimpreza's Avatar
Pandaimpreza is offline
95 would be a MAF. I would check your vacuum lines and ground wires. Also in the fuse box in the engine bay make sure your fusible link is intact. If you are still having problems then it is most likely your crank sensor going out. Get that thing replaced and it should fire up smoothly.
