#26 |
![]() Join Date: Oct 2011
Yes I have wheel movement. But I thought it was the cracked uniframe. I'm in a poker game ill read all this later
#27 |
I quickly read more. Lol energy suspension full bushing kit, 99si front hubs, an rear siR disc. Explicit speed mounts, an I have yet to add the front engine mount I have to crossmemeber. N yes I have lsd (t2t4)
#28 |
![]() Join Date: May 2007
All of those will help you out, but this may be the total solution to end it all. Check out some of the pictures in this thread, the white EF just looks dangerous, but he makes passes. Why are you running the EK hubs? Isn't there quite a bit of difference in the knuckle dimensions?
Honda-Tech link |
#29 |
![]() Join Date: Jul 2008
I would go for that front mount on the traction bar for sure. I as well as a friend of mine have busted the rear mount out of the transmission case from not running the front mount. It just helps keep the motor from wanting to rotate in the engine bay.
#30 |
Yea I'm on my second rear cross member. An broke a transmission bolt whole because cause it hit werid. I have what I need from speed360 but havnt put it on yet.
#31 |
![]() Join Date: Mar 2011
I haven't talked with anyone using EK front knuckles on EF.
Was there a reason why you went with that vs. using stock ef knuckles or perhaps even DA ones I don't have a picture of it but I recall the upper portion of the knuckle has a much different arch/angle than EF ones. I run dx/si knuckles and have a pair of ef ex knuckles when i need to slap on larger rotors on road course lapping sessions. |
#32 |
When I did the swap back in 2007. Explicitspeed360 suggested them to me. Bigger rotors, my axles I was told wouldnt fit for my dx. (That was wrong I found out later) they are taller. But they worked. Aliment was good.
#33 |
understood...
interesting that he would sugguest EK knuckles... |
Thread Tools | |
