Old 09/23/2012, 09:45 PM   #1
rex712
rex712's Avatar
rex712 is offline
Default swapping d15b into 97 civic hx
hi guys i have some questions i am swapping a d15b into my 97 civic hx i was wondering what all i need to convert to make this possible i know i need to get
obd2a-obd1 jumper harness,obd2-obd1 fuel injector harness, obd2 10 pin to obd1 dizzy adapter harness but what else am i missing i am going to be using a p28 ecu as well
Old 09/30/2012, 11:35 PM   #2
Default Re: swapping d15b into 97 civic hx
I'm guessing the d15b is the one that came in 92-95 civics? Is yes...
Just use the obd2 injectors, dizzy, and engine harness. Then run the ecu jumper obd2a to obd1. Run p28 ecu.
Old 10/01/2012, 08:52 PM   #3
hflshane
hflshane's Avatar
hflshane is offline
^^^ your correct. I've seen this done and it had hasport mounts. Any difference in subframes? Jw... The d15b does not have a spot for the evap purge solenoid to bolt the manifold either. So you'll have to figure that out too. I can't think of anything else off the top of my head. What engine was in the hx? A y7?
Life Begins at 9000rpm
Old 10/02/2012, 12:11 AM   #4
rex712
rex712's Avatar
rex712 is offline
Thanks guys for the input really appreciate it and it a y5
Old 10/02/2012, 07:46 AM   #5
Oh. Forgot to mention.... you have to use the y5 engine mounts.
Old 11/01/2012, 03:35 PM   #6
rex712
rex712's Avatar
rex712 is offline
okay and could i use the alternator on my car right know cause the d15b one is a circle plug
Old 11/01/2012, 03:56 PM   #7
Ya you'll use your current alternator
Old 11/01/2012, 09:50 PM   #8
rex712
rex712's Avatar
rex712 is offline
What about for the distributor do I need the jumper harness for that.
Old 11/02/2012, 05:20 AM   #9
Does he need to do something special to the cel light?
Old 11/02/2012, 01:17 PM   #10
I don't think he does, but I don't have any experience with the OBD2 wiring so I don't know the specifics.
As for distributor a jumper harness can be bought and used or you can rewire it.
Old 11/03/2012, 08:23 AM   #11
Use the y5 distributor, alternator, and mounts. Fir the evap... just forget about it bcuz you can just use the ecu jumper harness and run a p28 ecu. The p28 ecu will not be reading the evap as evap is only on obd2 and newer. Pm me for more questions and help.
