Old 11/12/2012, 05:56 PM   #1
asianboy3t
asianboy3t's Avatar
asianboy3t is offline
Default Need Help!!!!
I own a 05 eclipse gts..my car started fine this morning and drove fine to work without showing any signs of anything wrong with it.. i go to my first break and it will not start? My dash lights still light up and radio works..i thought it was my starter since it wont turn over..i turn the key the lights come one and i go to crank it and it clicks once then nothing? I replaced the starter and nothing? Took it in to get my old one tested and it came out still good and working..took my battery out and got it tested and thats still good..now im stumped and dont have a clue what else it could be? Relay switches? Ignition coil? Can anyone help shed some light on this?
Old 11/12/2012, 06:00 PM   #2
ThatGuyVanny
ThatGuyVanny's Avatar
ThatGuyVanny is offline
Default Re: Need Help!!!!
Have you gotten the Ignition coil checked? this happened to me and i found them my coil was corroded...
Old 11/12/2012, 06:02 PM   #3
asianboy3t
asianboy3t's Avatar
No i havent that was gonna be my next step cuz i dont know what else it could really be? Where exactly is the ignition coil located and how hard is it to change?
Old 11/12/2012, 06:07 PM   #4
ThatGuyVanny
i really didn't know i had to let the shop fix it because i didnt have the tools.....SMH but check you manuals they might have some about starters and stuff. it took mine about an hour because that motherfucker was slow. Oh and also check out youtube haha
Old 11/12/2012, 06:11 PM   #5
asianboy3t
asianboy3t's Avatar
Okay i will google it..but yea i replaced the starter already for nothing cuz my old one is still good too so now im just sitting her with two starters and and non running car..but thanks
Old 11/12/2012, 06:13 PM   #6
ThatGuyVanny
Alright no problem man i wish you good luck
Old 11/12/2012, 08:46 PM   #7
idk if its any help but i had the same problem as you on my 2g gst, and it was a blown fuse, has happened three times now,
Old 11/12/2012, 09:32 PM   #8
luis31
Jefe De Jefes
luis31's Avatar
luis31 is offline
Alternator
Old 11/12/2012, 09:48 PM   #9
The exact same thing happened to me one night. Found out my ground wire was a little fucked up and slightly corroded. Took it to work, cleaned it up, and its been running great ever since. If you haven't tried that yet, give it a shot.
Old 11/12/2012, 09:49 PM   #10
A 97 gst is a lot different than an 05 gts. My stratus is exactly the same aside from being a 4 banger.
Old 11/12/2012, 09:53 PM   #11
i know it is, but i fuse could be a possibity with his car as well, was just an idea from my own experience
Old 11/12/2012, 10:03 PM   #12
Fair enough lol.
Old 11/13/2012, 05:36 PM   #13
asianboy3t
asianboy3t's Avatar
Thanks for the help guys..went through all my fuses and they were good..checked my wires and figured it could b my power wire from my battery to the starter so went and bought a new wire and just tested it..the car started right up..so as i was disconnecting the old wires to put the new one in i realized the heads on the wires were kinda corroded so i cleaned them up and gave it a shot b4 i actually changed the wire and it was good..so i guess the corroded heads just werent getting enough power to kick start the starter..which sucks bcuz i couldnt c the heads bcuz they are underneath the power post thing..well i guess i got a new starter in there now..lol..thanks guys
Old 11/13/2012, 06:14 PM   #14
ha at least it was an easy fix!
Old 11/13/2012, 06:18 PM   #15
asianboy3t
asianboy3t's Avatar
Yea if i wouldve checked that from the start..lol instead i spent a few hrs out in the freezing cold changing the starter out for nothing
Old 11/13/2012, 09:22 PM   #16
mattcossel29
jackstand ballin
mattcossel29's Avatar
mattcossel29 is offline
Word of advice for any amature mechanic.Always check the free/cheap stuff first. Than if it is not fixed move to the harder and more expensive options.
Old 11/13/2012, 09:37 PM   #17
thats exactly what i do when i have a problem,
Old 11/14/2012, 08:24 PM   #18
asianboy3t
asianboy3t's Avatar
i sure will next time..beats putting all that labor in for nothing
