Old 12/20/2012, 06:44 PM   #1
alexbuck205
alexbuck205's Avatar
alexbuck205 is offline
Default overheating. 92 gsx
Ok so I went out in the snow and long story short my radiator and got covered in snow and I noticed it was close to overheating. I stopped and eventually got it home. I now have no heat blowing threw my vents and my battery and abs light are dimmely lit up.. ive replaced the thermostat and still the same thing happens. Any ideas? Waterpump?
05 CBR 1000RR REPSOL
07 Acura TL-S
Old 12/20/2012, 08:24 PM   #2
mattcossel29
jackstand ballin
mattcossel29's Avatar
mattcossel29 is offline
Default Re: overheating. 92 gsx
Water pump or low on coolant.
Old 12/20/2012, 08:27 PM   #3
i wouldnt think that the radiator being covered in snow would make it overheat. snows cold already and the heat from the radiator would melt it almost right away. check both radiator hoses to see if ones cold. also make sure you installed you thermostat properly because ive had people come into the shop that did it themselves and put it in the wrong way. as far as the lights, that would be an electrical problem so get the battery and alternator tested. just some ideas.
Old 12/20/2012, 08:37 PM   #4
alexbuck205
Lol thanks guys I over looked that the belt was gone.. got a new one and works perfect. Thanks!
07 Acura TL-S
Old 12/20/2012, 10:35 PM   #5
please tell your out doing a shitton of awd donuts in the snow?
Old 12/21/2012, 08:00 PM   #6
alexbuck205
Haha the only reason I got the car! Needs a skid plate though if anyone can make one!
07 Acura TL-S
Old 12/21/2012, 11:11 PM   #7
good deal, hope to see your car at meets when it gets nicer out,
