Old 01/06/2013, 11:55 AM   #1
alexbuck205
alexbuck205's Avatar
alexbuck205 is offline
Default 1g ang 2g maf plugs
I'm looking at purchasing a used GM maf conversion but its for a 2g does anyone know if the factory plugs are different?
05 CBR 1000RR REPSOL
07 Acura TL-S
Old 01/06/2013, 01:07 PM   #2
Default Re: 1g ang 2g maf plugs
Are you getting the MAF translator? But to answer your question, yes, they're both different. Otherwise they would only make one version for both. To put it simply, the 1g has a plug with 2 rows of 4 connectors on top of each other. 2gs have a straight plug with all of them lined up together. I know people have made 1g to 2g plug adapters before, but I've never seen one used on a translator.
Old 01/06/2013, 02:40 PM   #3
alexbuck205
Yes getting a translater and front mount kit. Thanks for the info!!
07 Acura TL-S
Old 01/06/2013, 03:33 PM   #4
No prob. I'm not sure about using a 2g translator on a 1g because the settings could be different. If you can find someone looking to trade that has a 1g version, I'd recommend that. Otherwise you can research a little to see if it will make a difference.
Old 01/06/2013, 04:00 PM   #5
alexbuck205
Yeah I actually found a guy on dsm tuners with a Fmic kit and gm maf with translator I got. Should have it next week hopefully!!
07 Acura TL-S
