Old 02/05/2013, 08:45 AM   #1
Jsevillano55
Jsevillano55's Avatar
Jsevillano55 is offline
Default mitsubishi eclipse syncro problem
i have a 95 mitsubishi eclipse with a 420a. i loved the car when i got it but i need help. about 2 months ago my car started scratching 2nd gear, and i searched every where for an answer. i was told to just put in a new tranny and others told me the syncro is about $100 but labor is a bit**. what can i do to fix this? i already put in new tranny fluid, clutch, and a clutch master cylinder. is there anything else i can do?
Old 02/05/2013, 12:09 PM   #2
Default Re: mitsubishi eclipse syncro problem
When a synchro goes out, it needs to be replaced or just double clutch into 2nd gear or skip 2nd entirely if you're not able to right now. If you can find a cheap used tranny, replace the synchro anyway before putting it in. On the 4G trannys you can double synchro 2nd gear, but idk if you can on the 420 tranny.
Old 02/05/2013, 05:14 PM   #3
Just take it to a machine shop and get the synchro fixed, itll cost just as much if not more to buy a used trans from a junkyard as fixing yours the right way, an the used one might have a bad synchro as well,
Old 02/05/2013, 07:25 PM   #4
thats why I said replace it if you find a used one.
Old 02/05/2013, 07:52 PM   #5
Most likely it isn't just the synchro causing the grind. A lot of times, it is also the dogs being worn as well.
Old 02/07/2013, 11:52 PM   #6
Jsevillano55
Thanks a whole lot ill keep all of this in mind. I was just thinking about replacing the tranny all together but if I can just get that synchro fixes then, I don't see why not give it a shot. All I did before was double clutch into second and it still scratched so I just skip and go to 3rd.
But what if I want to sell it? How much do you think I could get out of it? In the condition it's in it's perfect. Super clean, brand new cold air intake and radiator. Just before summer started I got low profile tires to.
95 Eclipse- sold
ls Hatch- DD
Old 02/08/2013, 04:49 AM   #7
kryzpowell
kryzpowell is offline
Oh I see your having a problem with your Mitsubishi? Maybe you can contact your dealership for this. Or if not your car maybe one of the recalls. Didn't you heard about it? Recently,
Mitsubishi Motors Corp. has issued a recall on over 14,700 i-MiEV electric vehicles worldwide, reports the AP. Faulty brakes can result in increased stopping distances and potential collisions. All i-MiEV vehicles in question were created between December 2, 2011, and September 7, 2012. Mitsubishi will reportedly contact those affected by this recall. Read more here...
Old 02/08/2013, 07:46 AM   #8
Jsevillano55
I didn't get it from a dealer. I got it from a private owner. And I don't think the 95 eclipse will fit in this category. Thanks though.
95 Eclipse- sold
ls Hatch- DD
Old 02/20/2013, 10:23 AM   #9
Dsmolition
Dsmolition is offline
LMAO did you reply to a bot?
First off, you need to find out why your synchro is bad. They do not magically go bad. The number one cause for failures is the wrong kind of gear fluid and your clutch dragging. You need to fix the other issues, otherwise getting a transmission fixed is a complete waste of time and money. It will not matter if you have 50 synchro’s on your second gear slider.
93TSI- 624 AWHP 500 AWTQ
EVO VIII RR GSR (yet to dyno)
Old 02/20/2013, 12:48 PM   #10
these transmissions should only be used with mopar nvt-350 fluid,
Old 02/27/2013, 08:23 AM   #11
Jsevillano55
the car had been sold.
95 Eclipse- sold
ls Hatch- DD
Old 02/27/2013, 09:09 AM   #12
Dsmolition
Well thats a good way to fix it haha.
