Old 02/24/2014, 09:36 PM   #1
jaydmdude06
jaydmdude06 is offline
Default B18 Dyno Results with RM cams and Skunk2 Ultra IM
First off i want to congratulate the owner for allowing me to be a part of this build. Thank him for taking the input and any suggestions that I gave him and hence getting the results that exceeded his expectations. It is a really simple setup that I had the opportunity to build for him and very budgeted as well. I street tuned it this past fall before it snowed and he finally dynod his car yesterday night and the results came out decent. The goal was to get close to 200 whp as the build was budgeted and the limitation of the stock head. This is what the setup consists of:
Induction:
3" intake
68mm TB
Skunk2 Ultra Street IM - Stock casting no runner cleanup or anything was done to the IM. I wanted to see the results of this IM in shelf form without any clean up or sort.
HEAD:
Stock P72 head - Ports were untouched
Valve Job - No blending into the throat etc, just a fresh VJ on a stock head.
Rocket Motorsports M22KE Cams
Rocket Motorsports SL Valvesprings
K-Series Retainers
Stock Valves
BLOCK:
81.50mm
YCP CTR Replica Pistons
Stock GSR Rods w/ARP Bolts
ACL bearings
OEM GSR Crank
FUEL:
ID725cc Injectors
E85 (Winter blend)
Prodigy Race Engines(P.R.E.)
R O C K E T M O T O R S P O R T S https://www.facebook.com/Rocket4Life
R.D.R.
240/153 82X89mm B http://honda-tech.com/showthread.php?t=3092090
Old 02/24/2014, 11:35 PM   #2
Default Re: B18 Dyno Results with RM cams and Skunk2 Ultra IM
Nice power. What header?
Love RM cams. A buddy of mine is still running his M21's on his turbo setup from 8 years ago.
Old 02/25/2014, 11:18 AM   #3
jaydmdude06
Thanks and that's great to hear that the m21 is still working well for your buddy. The header is a plm smsp replica.
R.D.R.
