Old 11/21/2010, 03:11 AM   #1
iMaTThew515
iMaTThew515's Avatar
iMaTThew515 is offline
Default no power to head unit?
im not really sure how it happened but im not getting any power to my cd player or my cigarette lighter, i checked all my fused and even re-wired my cd player but still nothing
Old 11/21/2010, 07:06 AM   #2
Bill
Closing Threads
Bill's Avatar
Bill is offline
Default Re: no power to head unit?
check the ground
Nothing is true......Everything is permitted
Old 11/21/2010, 10:41 AM   #3
iMaTThew515
Originally Posted by Bill View Post
check the ground
what am i looking for?
Old 11/21/2010, 06:12 PM   #4
jdmb18hatch
Retired
jdmb18hatch's Avatar
jdmb18hatch is offline
did you check ALL the fuses? the fuse box under the hood too?
Old 11/21/2010, 07:11 PM   #5
iMaTThew515
yea inside, under the hood, and the cd players fuse...i have no idea what else it could be
Old 11/23/2010, 12:01 PM   #6
alexbuck205
alexbuck205's Avatar
alexbuck205 is offline
do you have a multimeter? if you do check your voltage to your yellow wire (constant power) that wire should have 12v when the car is completely off and than check your voltage to your red wire (switched power wire) it should have 12v when your key is turned on.. also make sure and check your ground (black wire) hold your negative off your multimeter on the black wire and the power side ofyour multimeter to either your red or yellow wire which ever has power.. if it says 12v it means you have a good ground.. if it reads nothing your ground is bad.
05 CBR 1000RR REPSOL
07 Acura TL-S
Old 11/23/2010, 06:55 PM   #7
iMaTThew515
so what am i gonna do if i have a bad ground?
Old 11/23/2010, 09:49 PM   #8
jdmb18hatch
Retired
If you do happen to have a bad ground, just take your black ground wire from the back of the head unit and attach it to a good, clean spot of metal on the vehicle chassis.
how did you rewire the cd player? to ignition harness or fuse box?
Okay, as alexbuck205 said, if you have a multimeter (or worse case a test light) test both your +12v (yellow) and your ignition (red) wire on the back of the head unit. That will be the easiest way to diagnose your issue.
Old 11/23/2010, 11:34 PM   #9
iMaTThew515
Re-wired to the harness, alright ill give it a try...this is frustrated the hell outta me
Old 01/10/2011, 01:19 PM   #10
mr2boostin
mr2boostin is offline
just run a wire from the positive side of your battery to your red wire on the back of your cd player ( tuck it nicely and run this threw your fire wall ) next get another wire and run this to your fuse box or ignition from your yellow wire if you want the cd player to keep its memory / your setting for bass etc. after these two steps turn the cd player on and you should be good. If the cd player doesnt turn on after this its your ground find a metal surface that is free of paint and connect the black wire to this. ( dont forget to check all fuses in car and on back of cd player )
Old 01/10/2011, 04:50 PM   #11
iMaTThew515
got this taken care of months ago thanks for the advise but POST DATES there for a reason
Old 01/13/2011, 12:33 AM   #12
whitsingleslamer
whitsingleslamer is offline
Ya thats to me for checkin ur fuse cuz u couldnt do it lol
1998 White civic ls swapped sold
1997 ford f150 current
1998 gsr integra current
Old 01/13/2011, 10:43 PM   #13
iMaTThew515
HEY DICK! THANKS FOR THE HELP and I checked the wrong one
Old 06/14/2011, 08:39 PM   #14
BootLip
BootLip is offline
Always check fuses under the hood as well as inside the car. Sometimes the blown fuse will be labled something that seems like it wouldn't have anything to do with the radio.
