Old 02/04/2013, 01:48 PM   #1
cdcEGcivic
cdcEGcivic's Avatar
cdcEGcivic is offline
Default integra starter issue?
so if i leave my car to sit over night or about 4-5 hours then try to start it, i turn the key and it just buzzes.. and does it for about a minute then turns over slow as hell and starts. i thought it might of been starter but it doesnt happen all the time.. any thoughts?
1998 ls integra
Old 02/04/2013, 02:20 PM   #2
Default Re: integra starter issue?
Could be an.old battery issue. Either that or loose connection. My old civic with a b16a swap did the same thing. Sometimes starts and sometimes just clicks. I bought a newer starter and went to change it. Came to find out i had a loose connection on the starter and it fired right up. My fault for not checking first.
Have you tried popping the clutch to start it?
Old 02/04/2013, 03:17 PM   #3
Ej6kev
Functional!
Ej6kev's Avatar
Ej6kev is offline
Old battery, ,Starter , Alternator, or Dizzy. I've had this issue with my civic before. and I've done all I listed and now it works fine.
Old 02/04/2013, 04:15 PM   #4
Connections and your battery are the first things to look at. It's really cold lately which will kill a cheap battery easily. Easiest thing to do is grab a volt meter check your battery level immediately after turning the car off. Then the next morning when you're getting ready to leave quick pop the hood and check to see if the battery is holding it's charge well or not. I just had to replace one on my GF car yesterday.
Old 09/02/2021, 08:02 AM   #5
jdmciFRG
jdmciFRG is offline
Wow, that is awesome work!https://autowikius.com/
Sorry about the late post, I know you already bought your paint, but this is what I used:
Jeep*Lighting
Your steps are correct, although, you can save a step by not removing the chrome. If you scuff all the chrome good enough, you won't have any adhesion problems. You also don't have to wet sand, you can dry sand it just fine. You don't have to sand in between coats unless there are defects or something gets in the paint.
hckfridge2021@gmail.com
h.c.kf.r.id.ge.20.2.1@gmail.com
Check this out:https://autowikius.com/ ,nice automotive lighting store,may help you!
My To-Do List on my Sx4 keeps getting Bigger and Bigger !
1) Project Carputer
2) HID Triple Barrel HeadLamps
Yes only two things as of now but they it self keep expanding once you look at the items required in accomplishing the task.
Latest is the best Site I found for my HID Triple Barrel HeadLamp task.
https://autowikius.com/ ... }223{4}212
and
https://autowikius.com/collections/head-lights
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
